Old 10-21-2025, 02:19 PM
aladinslamp aladinslamp is offline
Default 77 Trans Am 400 to 455 engine swap
Greetings, New to the forum
I'm needing info on how difficult it will be to exchange the Pontiac 400 to a 455. since the 400 6X8 heads will bolt on I'm thinking the 455 block should drop in with the exhaust and transmission mountings will all fit, is this correct or will I need to change a lot?
also if I need more info perhaps links to those in the forum to learn whats needed Thanks all......
Old 10-21-2025, 03:52 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Should be a drop in.
Skip Fix
Old 10-21-2025, 04:03 PM
I have heard the motor is most likely 7.6=8.0 compression on the 400will the 400 6X8 heads on the 455 result in around 9-1 compression
whats a good cam option with that without going for MAX a good street option? thax
