Prev Previous Post   Next Post Next
Old 11-03-2025, 08:00 PM
Rachelsdad's Avatar
Default '63 Bonneville heat riser thermostat spring
Hi, all...
So, I've got a slightly weird issue with my heat riser not wanting to open quite all the way. The thing swings free, and when it's open (about 70% of the way?), it can be tapped/pushed the rest of the way with just a screwdriver, so it's not sticking. My thought is that the thermostat (which is what the coil spring is called in the parts manual) is just old and like the choke spring, not quite expanding all the way.
The problem I'm seeing is that while Ames has a spring for the 64-68, the one for the '63 seems elusive. I can't find a listing for it anywhere. The usual suspects have the anti-rattle spring, which is fine, but I need the bimetal coil.
The original part number for mine should be 9772543. I don't know how it may differ from the 64-68 spring. If mine is thinner (as in the ribbon being not-as-wide), I guess it could be ground down on a wheel. However, if mine is thicker, the later one may not have enough oomph to swing all the way open, leading to the same problem I'm having now.
Anyone with any suggestions or experience with these? There are outfits which make custom springs, but lacking proper specs, just having a spring wound with the correct outside dimensions may not be particularly useful.
Details, details!
TIA
Lewis
Lewis Rosenthal
'63 Bonneville Convertible
'56 Safari
'82 Firebird SE
POCI #3596 (since 1978)
