Old 11-06-2025, 01:59 PM
boardog boardog is offline
Default Front sway bar issue
Putting together my 70 gto and ran into an issue with the passenger side tie rod hitting the sway bar. Driver's side has about 1/2 to 3/4 inch clearance. Using the ridetech coil over conversion kit. Sway bar is a 1.25 inch diameter bar. The passenger side tie rod is almost against the bar. Both coil overs are adjusted the same. I don't know if i have the right idler arm or do I need longer sway bar end links? Anyone else have this problem using the big front sway bar?
ID:	660116   Click image for larger version
ID:	660117   Click image for larger version
ID:	660118   Click image for larger version
