I combed over 2 housings yesterday and was unable to find the codes. I thought, it shoudl be passenger side tube approx 8'' from backing plate, which should put it very close to the end of the crush on the 69 axle tubes. no luck, the housing i removed from my carousel red car is very very clean, yet no stamps that i could find. i looked on front side of tube and then i found some info saying it may be obscured by the brake line sometimes. no luck yet.
anyone point me in a likely direction it would be appreciated.
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
Supposedly on rear side about 3" from carrier on driver side.
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates |
| The Following 4 Users Say Thank You to johnta1 For This Useful Post: | ||
They can be very lightly stamped and invisible under layers of paint. I found mine, as mentioned above, on the rear of the tube, driver's side, 3 inches from carrier.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2015 Chevy Express ![]() 2024 Cadillac LYRIQ |
| The Following User Says Thank You to OG68 For This Useful Post: | ||
This.
1967 Firechicken, 499", Edl heads, 262/[email protected]" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. [email protected] mph with a 1.45 60'. Still WAY under the rollbar rule. |
thank you guys
This is where mine was located. Very light stamping easily covered by a heavy coat of paint. If there is corrosion pitting even harder to find. Don’t use sand paper to try to expose it as it may be light enough to make it worse. Wire wheel works well…
Picture per directions.
So long, farewell. |
| The Following User Says Thank You to Held for Ransom For This Useful Post: | ||
This is a good picture it’s a 69 Firebird rear.
