Old 11-08-2025, 10:17 PM
scld1354's Avatar
scld1354 scld1354 is offline
Default Pre-heater hose question
Cold weather is around the corner and I am trying to get a 68 GP ready for it. I'm working on the pre-heating system and cannot find the hose that goes from the exhaust manifold shroud to the 90* elbow on the bottom of the air cleaner. Both those pieces measure 2.25 inches. I cannot find any pre-heater hose online that measures 2.25 inches. The biggest I can find is 2 inches.
Has anybody had any luck finding 2.25 inch hose that will stand up to the exhaust temps?
Inline Tube sells the tube, but they don't specify the inner diameter. Has anyone ordered this piece from Inline? Did it fit?
Originally Posted by lust4speed View Post
Welcome to the broken nipple club - I'm a charter member.
Old 11-08-2025, 11:26 PM
Joe's Garage Joe's Garage is offline
Default This might work........
Not completely stock, but metal hose.
https://www.bigrigchromeshop.com/2-1...S11AprDJXvpuJn
They also offer it in 36" lengths.
Good luck!
Old 11-09-2025, 11:56 AM
burd burd is offline
You can buy the alum type at your local Napa.
Old 11-09-2025, 11:30 PM
Held for Ransom's Avatar
I get P/N 9797496. Which crosses to the Dorman 96024 or Gates 28095.
So long, farewell.
Old 11-11-2025, 10:29 AM
scld1354's Avatar
These are all 2" hose, and would fit inside the shrouds. I believe they are supposed to slip over the outside of the shrouds. Can someone post a pic of their setup?
Old 11-11-2025, 10:51 AM
The black ones are larger dia.
Old 11-12-2025, 10:42 AM
jd0n88 jd0n88 is offline
Here's a pic of the hose in my '76 GP. It slips over the exhaust shroud but is 2" inside diameter. Hope it helps
Old 11-17-2025, 11:21 PM
scld1354's Avatar
Thanks for the photo. I'll have to see if I can find a 2" setup from another car.
