Old 11-11-2025, 12:00 PM
dv657172's Avatar
dv657172 dv657172 is offline
Default Front Control Arm Upgrade?
Trying to plan for a few upgrades over the winter for my 65 GTO dedicated drag car.
Car has stock front Control Arms, stock springs front and rear (unknown specs), Lakewood 90/10 front shocks & 70/30 rear shocks, Hotchkiss Double Adjustable Upper rear control arms and boxed lower control arms. Car has been very consistent in 60' times and traction has not been an issue off the line.
Considering upgrade my front control arms for more adjustability and weight reduction.
At rest the car has basically zero camber and slight negative toe. However, lifting the front end 2.75" which is full suspension travel my camber goes to -2.6 DS and -1.1 PS while Toe goes to 1.12 positive on both DS and PS.
Thoughts, suggestions, recommendations all welcome.
I have looked at UMI, Global West and TRZ sets.
DV
1965 GTO Cameo White, Red Interior - 389, ST300 numbers matching
1965 GTO Black, Black Interior "Post" car - 389, M-20 numbers matching
1965 GTO Silver, Black Interior 100% dedicated drag car w/1968 400(461), 16x Heads, TH400, 3.90 9" Rear 1.656 60' 7.566 90.057 (1/8th)
1971 GTO Black (orig. Quezal Gold), Gold Interior - 400, TH400 numbers matching
1972 GTO Cardinal Red, Black Interior - 455, TH400 almost numbers matching
Old 11-11-2025, 01:23 PM
Mike S's Avatar
Mike S Mike S is offline
I went with Globel West upper control arm on the 67 last year. Made the car very stable at speed but made slow turns a lot harder. Wheels are straight when they come off the ground now.
Old 11-12-2025, 08:24 PM
dv657172's Avatar
Thanks Mike S for the feedback. Guess its not the most popular topic to discuss, lol
Old 11-13-2025, 02:51 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
The Global arms usually add more positive caster and on my IA/Camaro with a manual box are really tough to turn pushing in the staging lanes! But tracks straight!
Skip Fix
Old 11-13-2025, 04:30 PM
dv657172's Avatar
Thanks Skip Fix. Sounds like I may have to hit the gym this winter to get ready for next season. I am also using a manual box with a car and driver weight of 3,500 lbs.
It would be a big improvement to even get positive caster, currently I have -3.9 (DS) and -3.1 (PS).
Old 11-13-2025, 05:48 PM
performerrpm's Avatar
performerrpm performerrpm is offline
Send a message via AIM to performerrpm
i have the trz arms on my 65....really nice to look at....but i cant tell you how handle....car still currently underpowered @ 2 hand power
Old 11-13-2025, 05:55 PM
Skip Fix's Avatar
Yea almost enough for me to put power steering back on it!
Skip Fix
Old 11-13-2025, 10:44 PM
dv657172's Avatar
performerrpm - I have been thinking about those TRZ control arms. Good reviews on Yellow Bullet and definitely a bit cheaper too which is always nice.
Old 11-15-2025, 10:38 AM
gman005's Avatar
gman005 gman005 is offline
I have the TRZ on my car with a manual box.
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport. RIP
75 Grandville Convertible.
The Following User Says Thank You to gman005 For This Useful Post:
Old 11-25-2025, 05:05 PM
dv657172's Avatar
performerrpm & gman005 - what spindles are you running on your TRZ Control Arms?
Old 11-25-2025, 05:15 PM
aaronman aaronman is offline
I have TRZ upper/lowers on my 68 Bird. It's a drag car with a rack. I run Afco Double Adjustable front shocks which have a larger tube width and Landrum springs. The TRZ's are large enough to install them without modifications. You will need to align the front end afterwards and may need a bump steer kit installed. Take your car to a person familiar with bump steer modifications and good luck!
The Following User Says Thank You to aaronman For This Useful Post:
Old 12-03-2025, 03:44 PM
patches4392 patches4392 is offline
DV
Check with Smith Racecraft in Dallas. They build a bunch of stuff that's bad to the bone.
The Following User Says Thank You to patches4392 For This Useful Post:
Old 12-06-2025, 05:13 PM
gman005's Avatar
I have the factory spindles on my car.
71 Lemans Sport.
Old 12-06-2025, 05:36 PM
dv657172's Avatar
gman005 - Did you need to install a Bump Steer Kit also?
Old 12-06-2025, 08:27 PM
Skip Fix's Avatar
I think Global West makes some new steering arms that bolt to the spindle that deal with bump steer.
https://www.globalwest.net/product/a...air-bumpsteer/
Skip Fix
