Old 11-23-2025, 01:21 AM
chiphead's Avatar
chiphead chiphead is offline
Default 11 bolt water pump source?
My 11 bolt water pump just started leaking through the weep hole. This was a polished aluminum pump installed by the PO. Didn't last 2K miles.
Who has the best OE budget pump? Do any of the Rock Auto or Summit pumps have a cast iron impeller?
Old 11-23-2025, 06:28 AM
steve25 steve25 is offline
Our host of this site ( Ames performance ) carry’s at least 5 different pumps .
Old 11-23-2025, 12:04 PM
JLMounce JLMounce is offline
The machine shop that did my engine last year used a PRW unit. I've been driving the crud out of the car this past year and haven't had an issue with it.
-Jason
1969 Pontiac Firebird
Old 11-23-2025, 12:16 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Default waterpump
Agreed i also bought my 11 bolt from our host. no issues 8 years ago right after my
firebird was painted!!!! was real carefull changing that pump.
they had correct height pump with nice cast impeller.
Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds
Old 11-23-2025, 01:09 PM
And unless your racing and and looking to shed every last Oz of weight a cast body pump is the only way to go for max longevity.
Old 11-23-2025, 02:18 PM
AG's Avatar
AG AG is offline
I've used the PRW ali pump 3 times with success.
