Old 11-23-2025, 09:24 PM
74SDformula's Avatar
74SDformula 74SDformula is offline
Default What Diameter Rear Sway Bar - 1972 Formula
Working on a 1972 Formula. When I got the car, the rear sway bar had been removed. The front sway bar was present and is 1.125" in diameter. What should the matching diameter rear sway bar be? Thanks.
Old 11-23-2025, 10:13 PM
7/8" bar
Old 11-24-2025, 01:39 AM
Held for Ransom's Avatar
If you have Y99, I think 7/8" is correct. But standard would be 5/8". I could be wrong.
So long, farewell.
The Following 3 Users Say Thank You to Held for Ransom For This Useful Post:
Old 11-24-2025, 03:10 PM
65madgoat's Avatar
Check PHS to see if you have Y99 (trans am) suspension option....
Old 11-24-2025, 07:59 PM
necdb3's Avatar
necdb3 necdb3 is offline
Performance and handling PKG or "T/A suspension" in 72 would have a 1.250 front sway bar and the larger 7/8 rear bar with 15" tires. Sounds like your car does not have that suspension because of the 1.125 front bar.
Old 11-24-2025, 08:34 PM
SD73's Avatar
SD73 SD73 is offline
Going from my '73 Dealer album I'd say it stongly points to a 5/8th rear bar as being correct. As mentioned, if you had the bigger bar up front then you'd have gotten the larger bar in the back. You should get the PHS, but if I were a betting man I'd put money on the 5/8ths being correct for your car.
Old 11-24-2025, 09:58 PM
With the 1.125" front bar, I also believe it would have been spec'd with a 5/8" bar in the rear.
Old 11-24-2025, 10:20 PM
Thanks for the information everyone.
