Hi there, trying to located a pair of these in New Zealand if possible and need a part number. Its for the 9.3: rear end in 1963
Axle bearing that came out is 88128 which is the same as a lot of Ford and can be sourced locally Seal has no markings but dimensions as measured OD / Housing bore = 2.3725” Steel shell depth = 0.505” Shaft dia on axle = 1.524” Any help much appreciated
Working on going faster (and now staying dry at the same time !!) |
CR seal brand. NAPA part number NOS 15343
| The Following User Says Thank You to mgarblik For This Useful Post: | ||
Cheers for that, couldn't find anything local so ended up finding at rock auto.
