Clearing out some 2nd gen parts, can send more pics & info, will ship in USA or international for actual cost.
Set of 4 mid 70’s 15x7 rally 2 wheels $250 or will split up- In good condition with no damage, only light surface rust. One wheel was painted silver but cant tell with trim rings on, good set to repaint. Also have some average condition caps & rings. 1972 Firebird wood grain dash bezel, with AC, no rally gauges. Woodgrain is lifting/bubbling in some areas and a small area is creased but looks & installs ok for a driver. $60. 5 Black gauge rings for early year birds $75. Tons of later gauge rings $10ea for large, $5ea for small. 79-81 tail light fuel door and lever bracket- in decent shape but has surface rust on metal parts and lens has normal scratches/checking. $75 70?-81 Center link bar for steering- From a 1980 TA but should fit other years. In good condition with tight ends, rubber washer seals are torn but can be replaced. $50 70-81 AC/heat ducts & vents, don’t have all but some of the harder to find ones. Prices vary depending on which one. 70-81 Cold air intake fender duct- $25 73?-81 A-pillar trims, black. - $35 70-81 Black center console lid/box, decent shape but not perfect, no cracks in lid. $50 70-81 arm rests, dark blue almost black pass side, light blue driver side, no broken bolt holes. $50ea Pontiac timing cover early & late style for 11 bolt water pumps. $50 for 526985 w/out cast in timing tab, have others with tab. OEM Automatic flexplates- Good shape , multiples available. $25 shipped in USA. 70-81 hood latch- $40 70-81 steering wheels, horn buttons/switches, shifter knobs, cig lighters, other misc interior parts. Prices vary depending on part/condition. Lots of 80-81 Turbo 301 engine and other related parts. 1981 Turbo light switch and boost psi sensors. Send a message for what you need. Tons of other misc bolts, clips, emblems & other random parts for these cars, just ask for what you need. Lower prices than most ebay or other online sellers. |
more pics
Do you happen to have a '79 left side smoked tail light outer panel with the bottom reflector?
Let me have a Diablo sandwich and a Dr. Pepper and make it fast---I'm in a goddamn hurry! - Mike 1967 GTO |
going bandit-Reynolds style |
Yes, this is the duct that goes in the fender cavity then the shorter plastic piece connects to it then the hose to the air cleaner. Have 2 of these but none of the other parts right now.
For others interested in parts its probably better to send a message for pics/info vs bumping the thread up each time, more courteous to others to not bump the thread every week... |
Early spring bump. Some things sold and most other are open to reasonable offers. Lots more not listed, send a message for what you need.
Sold items from list- rally 2 wheels. A-pillar trims. Timing cover w/out tab but have others with timing tab. |
