Old 11-28-2025, 09:07 AM
P@blo's Avatar
P@blo P@blo is offline
Default SM mid-rise intake on saleio :)
It's Black Friday and see SM has their mid-rise intake manifold on sale. Is this a copy of the Performer RPM with the exhaust crossover removed and has anyone used one yet?
https://www.speedmaster79.com/Pontia...nifold-Satin_2
Old 11-28-2025, 09:53 AM
67Lemons 67Lemons is offline
I’m on the fence about buying one for the 455 I’m refreshing this winter, looks solid but I haven’t seen any feedback from anyone who’s running one.
1972 GTO
Old 11-28-2025, 05:40 PM
Half-Inch Stud's Avatar
Hmmmmm, Fuel Injector Bosses on a Dual-plane is thee ting for "carb break-in to FI run in a modern transplant project.
Been on my list to BUY, and -$115 means heck yes. This better be on the up & up.
Ordered. THANKS!
Old 11-30-2025, 01:54 AM
blueghoast's Avatar
Well can't help myself, I just bought a bunch of stuff from S-Master.
Single plane intake a set of there gold roller rockers look like HS
A billet 8000 MSD style dizzy, 2.19 intake valves a 2 inch blower spacer
Oh and a set of cometic style head gaskets .040 thickness 4.200 bore.
I thimk thats it. Was gona buy some more heads but I've got enough
of them for now. Still another day left get it while ya can.
Can't beat the prices.
GT
The Following User Says Thank You to blueghoast For This Useful Post:
Old 11-30-2025, 02:20 AM
NeighborsComplaint's Avatar
Have been running one on my 455 for years with Holley and most recently QJet. Nice intake, much better drivability than prior HSD especially in low and midrange. I like it plus I routed all wiring and hoses underneath it.
Triple Black 1971 GTO
The Following 2 Users Say Thank You to NeighborsComplaint For This Useful Post:
Old 11-30-2025, 02:56 AM
242177P's Avatar
242177P 242177P is offline
Originally Posted by Half-Inch Stud View Post
Hmmmmm, Fuel Injector Bosses ...
I'm thinking those aren't injector bosses, they seem to be
positioned awfully high in the port. And they've got even
more of them on the underside.
The Following 2 Users Say Thank You to 242177P For This Useful Post:
Old 11-30-2025, 07:37 AM
Squidward's Avatar
I use these, from when they were known as "Crosswind" intakes. Love them. The air gap makes a great place to run wiring and vacuum hoses.
The Following User Says Thank You to Squidward For This Useful Post:
Old 11-30-2025, 08:11 AM
jamaca85 jamaca85 is offline
I've seen them on the Butler website. if you run thin valve cover gaskets you might have clearance issues with those high injector bosses
1970 firebird, 468, e heads,
The Following User Says Thank You to jamaca85 For This Useful Post:
Old 11-30-2025, 10:29 AM
Does anyone know how the finish holds up on these? I’m thinking about the polished or the satin (painted blue to match)
1972 GTO
Old 11-30-2025, 10:34 AM
GT
Wow, you’re really tempting fate aren’t you with all the reports of EVERY rocker arm except for stock or stainless Crower’s blowing up if you look at them wrong. Half tongue in cheek but curious to hear your results since I need a set of rockers soon as well.
1972 GTO
Old 11-30-2025, 02:27 PM
...never got a SM79 order confirmation, but did take a photo of the Sale order with #.
Called SM79 and it shipps Monday.
Those better be capable of fuel injector drillings or the purchase is moot.
Old 11-30-2025, 02:56 PM
Dragncar Dragncar is online now
EVERY is a big word. Harland Sharp rockers still have a good reputation. I have some Norris SS rockers that have been bullet proof. Also have some Butler/Angus aluminum rockers that did not give me any trouble.
The Following User Says Thank You to Dragncar For This Useful Post:
Old 11-30-2025, 03:01 PM
It sure is which is why it was said tongue in cheek but there are a lot of reported failures around here which does make a person a little nervous when they consider buying anything other than the good ones frequently mentioned on this site.
1972 GTO
Old 11-30-2025, 04:59 PM
Squidward's Avatar
I left one natural, and painted the other with silver engine paint. The painted one cleans up, the natural one is a dirty abomination, like a grunge sponge.
The Following 2 Users Say Thank You to Squidward For This Useful Post:
Old 11-30-2025, 06:37 PM
I ordered the satin which I assume is natural so that I can paint it, sale ends soon.
1972 GTO
The Following User Says Thank You to 67Lemons For This Useful Post:
Old 11-30-2025, 06:57 PM
Steve C. Steve C. is online now
Not sure how this specific manifold was made but typically a mold will serve as the form for a casting.
Maybe the bosses in question on the top and underside of the manifold are involved in designing the casting pattern.
Old information here:
Old 11-30-2025, 07:04 PM
The single plane description states that it’s available machined for injection-
This manifold is a single plane manifold that will fit under all Pontiac hoods including the Trans-Am "Shaker" hood. It accepts a stock Quadrajet carb but we also include an adapter plate for standard square bore carbs. This manifold is designed to work with cylinder heads up to 300 CFM. It is also available machined for injectors.
The dual plane looks like it has similar bosses for injection but there’s no mention in the description.
1972 GTO
Old 12-01-2025, 07:20 AM
Opinion. The dual plane intake does not have the required material thickness for injector bungs.
The Following User Says Thank You to Steve C. For This Useful Post:
Old 12-01-2025, 04:29 PM
I resisted the Black Friday sale, proud of myself ! Not much I would want from them . Maybe their SFI T 400 case. But I was worried about having trouble with it. I will put my SW forward and direct aluminum drums in a OEM case and run it.
They do have some straight bolt billet 455 main caps for 97 $ but were not part of the sale. Solid chunk of steel so less chance to screw them up and they are cheap. I have a nice std 74 455 block. But thats another project and I have too many right now anyway.
Old 12-01-2025, 10:55 PM
blueghoast's Avatar
Last year I bought some of the black roller rockers. the fulcrum roller
seamed ok but but the small roller for the valve steams seam cheap and said
only 300 lbs of spring pressure, might use them on a small hft cam motor.
I hope the gold ones are better they claim 600 pounds of spring pressure.
I'll let ya all know what there like when I get them.yesterday I bought
some more stuff 7/16x2 inch rocker studs and a 1050 throttle body.
See if it will clean mine up with them having bleeds. bunch of other stuff
ordered too.
GT
The Following 2 Users Say Thank You to blueghoast For This Useful Post:
