My '66 GTO has a drivers side "remote" mirror. The "clip" or whatever is the proper name of it, that goes inside the door panel and holds the "control" piece against the door panel is missing. If I hold the control in my hand and against the door panel, I can adjust the mirror. Moves relatively easy. BUT, I dont have the piece to hold it that goes inside the door panel to hold it in place!
1) What's the correct name for it "Clip", "Slide", or what? 2) Where can I get one, as all I've found is the complete assembly? 3) Are the door panel clips hard to remove? And easy to break? And where can I get extras? AMES? 4) Not had the door panel off, is it fairly easy to remove? 5) Yes, I'm a bit mechanically inclined, but been 40 years since I've played with a classic/collector type car! And at 79, My fat fingers don't have the deft of touch they did when I was 40, or heck,even 60! Your help is appreciated, and "ENJOY YOUR YOUTH"....70 or less!! ![]() Thanks Allan |
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car.
| The Following User Says Thank You to Jeff Hamlin For This Useful Post: | ||
Did you try to contact Frank’s in California?
Sorry, I'm not familiar with "Franks"
Any contact information, website, etc, would be appreciated! Thanks, I'm kinda new at this restoration and parts suppliers. But there's a lot of information to be had/shared on here, and I for one, really appreciate it Allan |
Franks Pontiac Parts. They’re a huge salvage yard out in the desert in California. Nothing but classic Pontiac’s. You can call and talk to them, they are very helpful. Here is their link:
https://frankspontiacparts.com/ Last edited by tempest1964; 12-09-2025 at 10:11 AM. Reason: Edit hyperlink |
Panel insert Bezel/Retainer for Remote Mirror Control
I just bought one of Ebay. Ames has them as well
1967 GTO Sport Coupe 49,xxx orig.miles Champagne/Parchment 30 Original Owner Ordered PHS Documented Factory Options Second Owner |
| The Following User Says Thank You to 1967SC For This Useful Post: | ||
