Old 12-07-2025, 10:07 PM
post toastie's Avatar
Default 1966 GTO on market place with 4:33 gear option
66 GTO tri power. close ratio 4 speed with 4:33 option https://www.facebook.com/marketplace...5-9e450b2786a2
ID:	661870   Click image for larger version
ID:	661871   Click image for larger version
ID:	661872   Click image for larger version
Old 12-08-2025, 09:08 PM
He has a great car in one of my favorite 66 colors. Marina Turquoise (dark)
PHS must have sent him blank option sheets , or he printed his own copies , and did his own yellow highlights.
His BHC states axle code P = 3.90
But he highlighted S - 4.33 on his breakdown sheet. And campaigning 4.33 marketing strategy.
His AI source is either altered - or missed by a mile - about WS engines.
That is the info on XS code RA engines in 66
Those 2 hyperboles combined don't spell complete honesty.
Lots of boxes with numbers in them.
I'm going to do a breakdown on all those options.
Old 12-08-2025, 10:32 PM
09-459 = Unknown dealer in Cincy Ohio zone
State Code 15 is Kansas
Nov 15 1965 billing date
354 - AM/FM with manual antenna
352 - Reverb with rear speaker
376
372 - Spare tire cover
374 - Rear window defogger
382 - Door edge moldings
397
391 - Visor mirror
392 - Tilt rearview mirror
394 - Remote control rearview mirror
407
401 - Luggage lamp
402 - Glovebox lamp
404 - Roofrail reading lamps
417
411 - Courtesy lamps
412 - Ashtray & Lighter lamps
414 - Parking brake lamp
421 - Underhood lamp
431 - Custom seatbelts
448 - Rally gauges & Tach
473
471 - Custom sport (wood) wheel
472 - Console
486
482 - Exhaust splitters
484 - Metallic brakes
515
511 - Quick Steering - manual
514 - HD 7 blade fan & clutch
524 - Custom shift knob (wood)
531 - SoftRay ALL
621 - Ride & Handling
633 - Front & Rear floormats
664 - Transistorized Voltage Regulator
671 - Transistorized Ignition
70/71 - CB - White line tires
733
731 - Saf t track
732 - Performance Ratio
74P - 3.90 axle
75/76 - WS - TriPower manual
778 - Close Ratio M21
784 - 4 Speed
$3886 price
Said to be 23,000 actual miles
No details on Engine or Trans or Console or Shifter or Wood Knob
Wood Wheel not shown
Car may have 4.33 gears installed as a possibility after the fact
Radio , reverb & defogger switches appear intact.
Remote mirror toggle impression on door panel
The Following 2 Users Say Thank You to Baron Von Zeppelin For This Useful Post:
Old 12-09-2025, 07:47 AM
J GLASGO's Avatar
J GLASGO J GLASGO is offline
Lots of bs for sure
WWW.GLASGOPERFORMANCE.COM. Updated... Sort of!
The Following User Says Thank You to J GLASGO For This Useful Post:
Old 12-09-2025, 10:55 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
Exhaust Splitters on a ‘66.
Old 12-09-2025, 11:12 AM
Keith Seymore's Avatar
376 = 37-2 + 37-4 (2+4=6). The 6 is what gets reported in the box when both options are present.
Same for all the other blanks; ie
39-7 = 39-1 + 39-2 + 39-4 (1+2+4=7)
Etc
I'm guessing you know that based on how your response is formatted (nicely - btw) but mine was really hard to type so I'll leave it in case others may benefit.
K
'63 LeMans Convertible
'63 Grand Prix
The Following User Says Thank You to Keith Seymore For This Useful Post:
Old 12-09-2025, 11:24 AM
482 should be exhaust tips.
I got carried away.
Old 12-09-2025, 11:35 AM
It's a helluva car
Great color combo and upwards in options.
I don't see the need to hyperbole about the WS engine and 3.90 axle like that.
Old 12-27-2025, 09:54 AM
lugnutx2 lugnutx2 is offline
I talked with owner and got some more details about the car, he knows the history of the car well. The original engine, trans, shifter, rear end, ram air pan, sport steering wheel & console are all long gone. He thinks all of the other options are present. It's a had 5-6 different engines installed over the years, including several BBC. It's seen some track use, mostly street raced, right now it's a roller with a T 10 4 speed, V gate shifter and a Chevy 12 bolt rear. It comes with some replacement parts big car 389, 093 heads, replacement 66 tri power, miscellaneous brackets, pulleys etc... He also has new PUI seat covers and door panels. He wasn't sure, but he thinks he might have some parts of the TI ignition. It's a neat car, I'd like to own it, but at 30K it have to be a labor of love. If it gets cheaper I'll go check it out and post some pictures.
The Following User Says Thank You to lugnutx2 For This Useful Post:
Old 12-27-2025, 11:24 AM
FMile Pontiacs's Avatar
FMile Pontiacs FMile Pontiacs is offline
I think this car is located in Lexington Ky
The Following User Says Thank You to FMile Pontiacs For This Useful Post:
Old 12-28-2025, 10:33 AM
Longs's Avatar
Longs Longs is offline
For the seller having a lot of information and history on the car (aside from potential misrepresentations about the 4:33) and supposedly having PHS documents, he posted a really half-assed ad on Facebook Marketplace with terrible photos. That car had interesting options but it's had an extremely hard life and is in rough shape; multiple drive trains, original long gone. It seems like some people use Facebook Marketplace hoping to lure potential buyers who will pull the trigger on impulse, thinking that they're getting something unusual. "Rare" doesn't necessarily translate into something being more valuable.
Old 12-28-2025, 11:11 AM
I talked with the seller again, he's firm at 30K, and still insists it's 1 of 190 built. I told him the PHS is incorrect, probably came with a 390 rear and they built lots WS cars in 66. I do believe his story about dealer installed ram air, 4:33 rear end, cam etc.. I can see that happening. Neat car, but I bailed at 23K, more if delivered. He seems to be an honest guy, he's just getting some bad information from somewhere. Anyways, he's taking it to Norwalk, hopefully I can check it out better there.
Old 12-28-2025, 02:29 PM
His PHS document is the gospel. It shows code P 3.90
Someone made the error of yellow highlighting 4.33 on the copied order sheet.
Anyone could do that accidentally or purposely.
Entirely possible the buyer had 4.33 and Ram Air installed , but if they are no longer with the car it's a moot point.
The buyer also had the opportunity to have ordered it as XS with Ram Air and 4.33 from the start.
But they didn't
If his BHC was coded XS engine with S axle he could get 30k +plus for it easy .
