Old 12-22-2025, 09:24 AM
grivera's Avatar
grivera grivera is offline
Default Merry Christmas- Summit Racing 10% Off Coupons
Here are seven Summit Racing coupons for the PY family Christmas stockings! These are specifically numbered for single use and you have to place the order once entered in the check out screen. In other words, the cart won’t save it with the items and the code will be considered redeemed.
If you decide to use one, please reply which number you used so another member doesn’t try to use the same number. Shared with the honor system in mind so please do not sell the codes on eBay. Also, in the Christmas spirit please only use one so others may have an opportunity to save some money. These expire on 12/31/25
ID:	662540   Click image for larger version
ID:	662541   Click image for larger version
ID:	662542   Click image for larger version
Will Rivera
The Following 9 Users Say Thank You to grivera For This Useful Post:
Old 12-22-2025, 03:30 PM
P@blo's Avatar
P@blo P@blo is offline
Thanks Grivera!
I used ZE73615377 that was the single code in the last picture. Merry Christmas 😊
The Following User Says Thank You to P@blo For This Useful Post:
Old 12-23-2025, 10:19 AM
67Lemons 67Lemons is offline
Thanks! I’m working on an order using the first coupon (4370) as soon as I finish loading my cart up and placing the order I’ll come back to this thread to note the coupon is used.
1972 GTO
The Following User Says Thank You to 67Lemons For This Useful Post:
Old 12-23-2025, 01:15 PM
I ended up using the second code in the first picture since it wouldn’t accept the first, I used code ZE76615371, thanks and merry Christmas!
1972 GTO
Old 12-23-2025, 01:39 PM
grivera's Avatar
If any issues entering codes try a phone order. They were unused when posted so all should have worked. As I mentioned, do not enter until fully checking out
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
Old 12-23-2025, 01:47 PM
tstroud tstroud is offline
I just used ZE70615373. I tried 79614378 but it got stuck.
Thank you Grivera!
The Following User Says Thank You to tstroud For This Useful Post:
Old 12-23-2025, 07:29 PM
Stan65 Stan65 is offline
I used code ZE74615375. Thanks and merry Christmas!
The Following User Says Thank You to Stan65 For This Useful Post:
Old 12-28-2025, 04:24 PM
TammyTA's Avatar
TammyTA TammyTA is offline
Looks like they are all used up. Darn!
Old 12-28-2025, 04:48 PM
grivera's Avatar
I may have one more I can send you in 12/31
Will Rivera
Old 01-01-2026, 12:48 AM
grivera's Avatar
Sorry- didn’t find it.
Will Rivera
