Old 12-26-2025, 09:57 AM
DANTIP DANTIP is offline
Default California NOX Exempt label
This label is on the inside of the original windshield of my '66 California Tri-Power /4-speed GTO. I was told by a previous owner that this California NOX "EXEMPT" label was placed on cars that met certain exemption rules at the time. He thought "Tri-Power" cars qualified for the exemption. Does anyone have any details related to these labels?
The Following 2 Users Say Thank You to DANTIP For This Useful Post:
Old 12-26-2025, 12:03 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default NOX Box
Dan,
I’m thinking it was a 70’s thing in California.
In order to pass smog you needed to attach this ugly item under the hood and connect as instructed on the box.
I saw many of these back in the day and I have this nice example from years gone by.
My ‘66 still shows the outline of this decal on the inside of windshield.
I found an old decal years ago and temporarily glued it to the outside as an example.
Also found several new ones on line too.
Chris
ID:	662695   Click image for larger version
ID:	662696   Click image for larger version
The Following 2 Users Say Thank You to 60sstuff For This Useful Post:
Old 12-26-2025, 12:07 PM
60sstuff's Avatar
Default The Box
Ugly back then, but kinda cool today.
ID:	662698   Click image for larger version
ID:	662699   Click image for larger version
ID:	662700   Click image for larger version
The Following User Says Thank You to 60sstuff For This Useful Post:
Old 12-26-2025, 12:36 PM
OG68 OG68 is offline
Back in the early 80s I went down to have my 68's annual smog test done at a local gas station. I figured I'd have to have the NOX device installed. The tech proceeded to do the visual inspection and announced that I didn't need the NOX device since I had a 'Ram Air' engine. Wink Wink. That was news to me but I went along with it lol.
Apparently RA engines were exempt from the NOX device.
He proceeded with the required smog test, and attached an EXEMPT sticker to the lower right windshield.
The Following 2 Users Say Thank You to OG68 For This Useful Post:
Old 12-26-2025, 12:41 PM
Originally Posted by 60sstuff View Post
Dan,
Chris
Chris,
I was hoping you would have knowledge of this! Of course you had a NOx box tucked away in your amazing parts stash!! Here is a document I just received via email on the topic. It is reportedly from a vintage California State Police vehicle inspection manual.
The Following 4 Users Say Thank You to DANTIP For This Useful Post:
Old 01-08-2026, 11:42 PM
mgarblik mgarblik is offline
That is some crazy cool stuff there!! As a former EPA emissions instructor, I would love to know what was in that box and what it was supposed to do and how? The only practical way to reduce NOX in those days was to reduce combustion temperature. Running an engine rich would accomplish this but drive HC and Co emissions up. Very interesting, Thanks for sharing.
Old 01-09-2026, 07:22 PM
gto4ben gto4ben is online now
The internals consist of a 555 timer, op amp, transistors, solenoid valve. capacitors and resistors. The 555 timer senses the RPM and triggers a signal to activate the solenoid valve which closes vacuum port to the distributor vacuum advance canister. Below the set RPM, it bleeds vacuum from the atmosphere to disable the canister operation. The setup is not unlike the 70-72 TCS system.
If anyone has the instruction manual for the Electro Nox, please scan and post it. I'm interested in what Air Quality Products recommend for the RPM setting, similar to what the Carter 5600X instruction say.
ID:	663393   Click image for larger version
ID:	663394   Click image for larger version
Name:	wiring transparent.jpg
ID:	663395   Click image for larger version
Name:	Carter 5600X RPM settings Pontiac.jpg
ID:	663396   Click image for larger version
