Old 12-29-2025, 02:22 PM
GVbird GVbird is offline
Default 1975 Formula AC/Heater vacuum line manifold tube placement
Hello everyone.
- I am new and was recommended by my "Pontiac Camshaft Guy", Lee Atkinson.
-My son was given his Uncle's original owner 1975 Pontiac Firebird Formula 400.
-We are in the process of putting the car together and I have 4 vaccum tubes from the heater box (Yellow/White/Blue/Brown) and 1 from the engine compartment (Black).
-The tubes are not in the rubber manifold at the heater control unit.
-The control unit has 5 ports labled: 1, 2, 3, 4, 7
-I cannot find any diagram to match the numbers on the manifold to the tube color.
-I appreciate any/all assistance
Name:	Firebird heater control vacuum manifold.jpg
The Following User Says Thank You to GVbird For This Useful Post:
Old 12-29-2025, 06:24 PM
jerry455 jerry455 is offline
I did a heater core on my 1976 Firebird last winter, and I thought the tubes were all together in one connector making the reconnecting simple. I will try to find some pictures.
Old 12-29-2025, 08:46 PM
Thank you.
Yes, they are all on the manifold, but being a rookie Pontiac guy I didn't realize that it separated from the heater control.
Old 01-01-2026, 01:49 PM
Did you figure this out? I was just looking through my 1976 Factory Assembly Manual and I found a drawing of the vacuum hose diagram.
Old 01-01-2026, 02:28 PM
I have not found any diagrams on the manifold port to tube colors.
Really odd as some of the manifolds sit at the rear of the heater control, while my son's sits facing downward
Old 01-01-2026, 02:29 PM
Old 01-01-2026, 02:48 PM
This is from the 1976 Firebird Factory Assembly Manual.
Name:	HVAC 76 F BODY.jpeg
Old 01-04-2026, 03:58 AM
Thank you. That is the same printout I found for a 1978. I may have to just run air through the manifold and move the lever to see what position corresponds.
Old 01-04-2026, 01:15 PM
Held for Ransom's Avatar
1973-6 should be the same, maybe more. Here are the sheets out of the '74 manual. As you can see, doesn't really show how they are mounted on the plastic fitting.
If you;re assembling a car taken apart, you should invest in the assembly manual. Maybe even this one, which has '73 and '74 too, it's just not a hard copy. https://www.ebay.com/itm/405021553554
ID:	663107   Click image for larger version
ID:	663108   Click image for larger version
So long, farewell.
Old 01-04-2026, 11:24 PM
Thank you, I have invested in that exact manual, but it did not give the same number of tubes.
With the exception of one extra tube on your diagram, to color tube to manifold number is correct!!
I have a good friend, that had a shop, saved all hisold manauls. He had a 5 inch thick manual just for GM/Buick/Olds AC/Heat systems, he found the exact one for my son's car. It was under 1974 because the car was manufactured in 1974, but sold as a 1975.
These cars have LOTS of "moving parts"!!
Thank you so much for the help and posting!!
Old 01-05-2026, 08:12 PM
Here is what one of my '74s had...
ID:	663191   Click image for larger version
So long, farewell.
Old 01-06-2026, 02:10 AM
PERFECT!!!! Thanks
