Old 01-12-2026, 11:57 AM
Joe37 Joe37 is offline
Default 1967 carburetor 7027262
Looking for information about the metal cover over the bowl vent actuated by the accelerator pump. According to my Rochester Master information manual, the cover was not offered in '67, they started listing them in '68. This carb I'm working on didn't have one, it did come off an original low mileage car.
I see the covers on some '67 and others without. The service manual just has copies of the Rochester pictures, so no help there. This car is a non-A/C, 400 automatic, p/s. , no Ram Air or HO.
Also curious about the small bellows / boot over the accelerator pump rod that keeps dirt out, was that ever a standard piece?
Joe Hand
Old 01-12-2026, 12:09 PM
unruhjonny's Avatar
Originally Posted by Joe37 View Post
Looking for information about the metal cover over the bowl vent actuated by the accelerator pump. ...
As I have understood it, this was not used on 1967 Pontiac Quadrajets.
I believe it was also absent on Chevrolet Quadrajets for other years (I am thinking they were present for 1970, but not 1969 or 1968) - so it was not a standard piece, but rather it's an item that often appears to be added by people "restoring" these carbs.
Joe Hand
As I have understood, it was only a part used on 1968.5-1972 RAII/RAIII/RAIV, and 455HO application Qadrajets.
These first showed up (again, as I have understood it) on the 7028270/7028273 Quadrajets - but my gut says they were absent from the earliest units.
In essence, the airhorn needs to have been finish machined to accept the retaining lock washer - other airhorns didn't have this feature (this is from my personal observations).
1970 Formula 400
Old 01-12-2026, 02:35 PM
gto4ben gto4ben is offline
According to the Firebird Rochester carburetor chart section and the Delco Carburetor Bulletin 9C-6001, idle vent shield 7035431 was first used on '68 quadrajets. The part was not listed on the '67s.
Name:	first used in 1968.jpg
The Following User Says Thank You to gto4ben For This Useful Post:
Old 01-12-2026, 05:32 PM
That's just what the Rochester manual shows, just one less part I have to trck down. Thanks for the information,
Joe
The Following User Says Thank You to Joe37 For This Useful Post:
Old 01-14-2026, 09:10 AM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is offline
It’s difficult to use the terms “always” and “never” when it comes to this stuff.
The 7028270 pictured is an NOS carb as far as I can tell. Not certain the story on it.
But it has the dust boot feature, plastic fast idle cam, vent cover and pick code. I haven’t seen many of these carbs and am not sure why the cam is green. Seems most Pontiacs were brown or tan.
ID:	663646   Click image for larger version
Old 01-14-2026, 07:34 PM
242177P's Avatar
242177P 242177P is offline
Except NOS is hardly representative of what rolled
off the assembly line. Some of those are parts that
were made during the initial run. While other stuff
is merely service replacement parts. The difference
between the two can be massive. Explains why the
fast idle cam is the wrong color.
Old 01-15-2026, 09:13 AM
Kenth's Avatar
Kenth Kenth is offline
I have found that the color of the fast idle cam changes from light green to tan/yellow after a some decades usage and thousands heat cycles, sitting right above the intake crossover channel.
Much like the silver-blue engine color changes to a greenish hue.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 01-15-2026, 11:50 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
Back in the day (70’s 80’s) you could purchase that factory correct greenish hue.
Love this color that started in 1966.
Not thrilled with that silver stuff.
ID:	663679   Click image for larger version
The Following 3 Users Say Thank You to 60sstuff For This Useful Post:
Old 01-15-2026, 12:30 PM
Kenth's Avatar
Yes, 1966-70 silver-blue metallic is one of the nicest, if not THE nicest, engine color when newly painted.
Unfortunately after some decades of using these cars this color turns greenish.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 01-24-2026, 10:44 AM
Longs's Avatar
Longs Longs is online now
My '67 was built in June 1967 at the Pontiac plant, 335 HP automatic with air conditioning, original 7027262 Rochester Q-Jet. No cover over the bowl vent, no rubber boot on the accelerator pump shaft.
The Following User Says Thank You to Longs For This Useful Post:
