Old 01-14-2026, 02:59 PM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Default Front drum brake backing plates.
I need both front drum backing plates with the 6 pads in great condition.
Mine are worn bad with groves cut in from the shoes.
I think they are the same from 64-72
Thanks, Dave
Old 01-18-2026, 10:37 AM
dhcarguy's Avatar
Nobody in the process of changing to Disc brakes?
Old 01-18-2026, 01:45 PM
ROCKETMAN269V's Avatar
ROCKETMAN269V ROCKETMAN269V is offline
I should have some clean southern parts; will have to verify. Thanks, Bob.
Old 01-18-2026, 08:04 PM
KGTO's Avatar
KGTO KGTO is offline
I should have a pair of the fronts, and the rear too. I'll try to get pics later.
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @164 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
Old 01-19-2026, 01:19 AM
dataway's Avatar
dataway dataway is offline
Frank's Pontiac Parts has probably got some.
Old 01-19-2026, 12:40 PM
dhcarguy's Avatar
to get pics later.
Thanks KGTO,
If the shoe pads on the rears are nice, I would take those also.
I really need the fronts for now. The 6 pads the shoes ride on with mine are badly worn with grooves cut in them.
Thanks, Dave
Old 01-19-2026, 12:46 PM
dhcarguy's Avatar
Thanks Bob
Old 01-19-2026, 01:54 PM
Originally Posted by dhcarguy View Post
...The 6 pads the shoes ride on with mine are badly worn with grooves cut in them.
A competent welder could repair the pads easily.
Old 01-21-2026, 03:46 AM
Scott Thelander's Avatar
weld up your originals,,, then hit em with the dremell to make the divits for the lube
I have a couple pairs but im sure they will need attention...
1 set is from a 70,000 mile 68
Old 01-22-2026, 09:03 AM
chrisp chrisp is offline
Have NOS $300 or good used set $150
Old 01-23-2026, 10:00 AM
dhcarguy's Avatar
Default backing plates
Thanks Paul,
I have a (Supposedly) good set coming from Idaho. He said the pads look good on both. the pictures were not very clear.
I mailed payment today. $70.with shipping. If they don't pan out I will give you a call.
Thanks, Dave
Old 01-27-2026, 09:33 AM
NOS set is sold
Old 01-28-2026, 12:03 PM
newmexguy newmexguy is offline
Late to the party, but probably have up to eight pairs. Take offs from literally decades ago. Surface rust only, no "de-icing" chemicals used here.
Dave S. las Cruces NM 88012
Old 01-30-2026, 10:36 AM
dhcarguy's Avatar
Default front plates
Hi Paul, I sent you a Text msg.
Dave
Old 02-03-2026, 08:13 AM
dhcarguy's Avatar
Hi Dave,
Any luck with finding a good L&R pair.
Thanks, Dave H.
Old 02-04-2026, 02:41 AM
Pecosbill's Avatar
Thanks, Dave
I've got a deal for you! I'm clearing out my stockpile of 64 and 67 parts and I've got two complete front hub assemblies including backing plates, brake drums, brake hardware, etc. all for the grand total of $50 plus shipping for the pair. Selling as a complete assembly, but at this price you cannot afford to NOT get the whole thing. The drums alone are worth more than $50.
Bill
ID:	664603   Click image for larger version
ID:	664604   Click image for larger version
ID:	664605   Click image for larger version
Pecosbill
Old 02-04-2026, 09:59 AM
dhcarguy's Avatar
Bill
Thanks Bill, that IS quite an offer. The only thing I needed was just the Front backing plates. I do have a nice pair on the way(hope they are better than mine). The pics of them look good. I have everything else NEW. Just the shipping for 4drums cost $81 dollars.
If you lived close to me I would certainly take them.
Thanks again, Dave
