Old 01-15-2026, 04:29 PM
android 211 android 211 is offline
Default Inaccessible
I have to remove my power brake booster on my '69 convertible. Is it recommended I take off the drivers side fender? The two nuts that secure it on the outside are really hard to get to.
Second my oil pressure gauge reads 80+ all the time. This happened when I swapped engines. My car has ac and the blower motor has stopped blowing. After checking fuses and replacing the blower motor and the relay it still doesn't blow. The dash switch had gone suddenly very stiff prior to the blower motor failure. Should I drop the whole dash to get to the oil pressure gauge and the fan switch? I took out the glove box and getting to the switch is still near impossible. I'd be grateful for any input.
Old 01-15-2026, 05:51 PM
73ta's Avatar
73ta 73ta is offline
Check wire going to blower motor for voltage with a meter.
Old 01-15-2026, 06:55 PM
You may need to make a one-off 9/16 box wrench by purchasing or sacrificing a wrench then heating it up and bending it to snake in behind the booster.
Old 01-22-2026, 05:06 AM
locomotivebreath's Avatar
locomotivebreath locomotivebreath is online now
I used a stubby flex head ratchet wrench from gear wrench to take the booster off my 68 - took minutes . Absolutely no need to remove a fender .
When I wore a younger man's clothes
The Following 2 Users Say Thank You to locomotivebreath For This Useful Post:
Old 01-24-2026, 10:04 AM
thank you everyone
Old 01-24-2026, 10:57 AM
propuckstopper propuckstopper is offline
One hundred percent this ^^^
Don't dive into fender removal.
Old 01-26-2026, 05:27 PM
comanchefirebird comanchefirebird is offline
I had to cut down a cheap wrench and even grind the box end thin as the booster bracket was too close to the nut. Tedious but it worked.
ID:	664219   Click image for larger version
The Following User Says Thank You to comanchefirebird For This Useful Post:
Old 01-29-2026, 09:22 AM
Thank you guys I'll get on it this weekend. Bought the flex end rachet wrench.
Old 01-31-2026, 12:54 PM
NOVAGOAT NOVAGOAT is offline
I use my flex-head wrenches almost every time I wrench on my cars. I was skeptical at first, but they are very practical wrenches.
