Old 01-17-2026, 12:15 PM
Default 1971-1972 GTO & Formula ram air cleaner ID
I have three ram air cleaners off of 1971 - 1972 A-body and 70 - 74 Formula cars. All three have minor variations in construction. I'm trying to determine what application each of these fits. I know one is 455HO because it has a hot air tube on the passenger side, but I'm not sure what year. I'm also not sure of what the other two are. I suspect one could be bought over the counter.
See the photos. Air cleaners from left (1) to right (3)
Differences:
Air Cleaner 1 D-port (left)
- 4 wire/vacuum hose clips on bottom
- One flat at back
- Flat straps on dashpots
Air Cleaner 2 455HO (middle)
- 2 wire/vacuum hose clips on bottom
- Two flats at rear
- Curved dash pot straps
Air Cleaner 3 D-port (right)
- 3 clips, appear to be dual (different from other air cleaners)
- One flat at rear
- Flat straps on dash pot
ID:	663772   Click image for larger version
Old 01-17-2026, 12:16 PM
Here are some close up photos of air cleaner 1.
ID:	663774   Click image for larger version
Old 01-17-2026, 12:17 PM
Air Cleaner 2 (middle).
ID:	663776   Click image for larger version
Old 01-17-2026, 12:18 PM
Air cleaner 3 (right)
ID:	663778   Click image for larger version
Old 01-17-2026, 01:00 PM
Held for Ransom's Avatar
What do you want for the middle one?
I'll look for the thread of mine.
Here it is...
https://forums.maxperformanceinc.com...d.php?t=872998
So long, farewell.
Old 01-17-2026, 01:08 PM
1. 1974. 2. over the counter replacement of 1971-2 and 3. 1973.
No tag or even glue residue on the sides of base?
So long, farewell.
Old 01-17-2026, 01:22 PM
I need one 455HO air cleaner for my 1972 455HO convertible.
I'm trying to determine if the 455HO air cleaner is a 1971 or 1972. I thought there was a difference between 1971 and 1972, but I don't remember what it is.
I'm not sure what you're asking "No tag or even glue residue on the sides of base?" The no 1 air cleaner has a piece of tape covering the two holes at the back. I'm not sure why it's there. I think that one either hasn't been run, or has been cleaned up before I got it.
Old 01-17-2026, 02:32 PM
The difference was studs (1971) vs no studs (later in '72) on the diaphragm hold down.
If you have no tag or residue, it's been restored or an over-the-counter replacement. The scalloped hold down didn't show up until the '77 Pontiac air cleaner.
So long, farewell.
Old 01-25-2026, 10:36 PM
74SDformula's Avatar
74SDformula 74SDformula is offline
This is off of a late '72 Formula.
ID:	664195   Click image for larger version
ID:	664196   Click image for larger version
ID:	664197   Click image for larger version
Old 01-25-2026, 11:35 PM
Interesting on the late '72 RA air cleaner. Usually the later ones had no studs.
So long, farewell.
Old 01-26-2026, 01:56 PM
I junked a 1972 Formula 455HO many years ago, the air cleaner was in the trunk and was covered in surface rust. I don't think it had the stud on it. If I remember correctly, it was a December 1971 built car.
