Old 01-18-2026, 10:21 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Default R&R front to back brake line
Doesn't look like to me that it is possible.
Has anyone replaced the front to back brake line on a 65 GTO.
will the one piece line in the kit have to be cut and then reconnected with a union?
Thanks, Dave
Old 01-18-2026, 10:32 AM
grivera's Avatar
grivera grivera is offline
I installed a stainless steel brake lines in my 66 and the line is two pieces.
Will Rivera
Old 01-18-2026, 11:57 AM
JLMounce JLMounce is offline
Different car, but I did get a 1 piece brake line in my 1969 Firebird. It was an absolute pain and I don't know if it would have been possible without my lift. There should be availability of 2 piece brake lines. These will be much easier to install, at the expense of having a joint.
-Jason
1969 Pontiac Firebird
Old 01-18-2026, 12:23 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Made my own from long line from Oreilly and a coupler in the middle on my 65
Skip Fix
Old 01-18-2026, 01:16 PM
dhcarguy's Avatar
Thanks , looks like I won't even try. 2pc. with a union I guess
Old 01-18-2026, 01:50 PM
steve25 steve25 is offline
The last time I replaced a 1 piece line of it was not for having the body off the frame I would have never got it done!
Old 01-18-2026, 03:28 PM
george kujanski's Avatar
george kujanski george kujanski is online now
On my '67 I did a stainless line but I needed to bend it more than I wanted to get it over the rear xmember. Not bad otherwise.
George
