Old 01-24-2026, 05:05 PM
gtopaul13 gtopaul13 is offline
Send a message via AIM to gtopaul13
Default 64-65 tech
64 question does anyone new the color for ignition one ans two one the ignition switch thought one was pink with blck stripe other wire i no clue thanks for help
The Following User Says Thank You to gtopaul13 For This Useful Post:
Old 01-24-2026, 05:43 PM
At the switch, Pink double black is for the power.
The other wire at the switch is Pink which goes to the coil.
Old 01-24-2026, 08:55 PM
BOB VIDAN BOB VIDAN is offline
Where in the H did you go to school???????????
Practicing social distancing for 65+ years
The Following User Says Thank You to BOB VIDAN For This Useful Post:
Old 01-25-2026, 12:43 PM
My wife says he must not speak English. ????????
Old 01-25-2026, 03:49 PM
thanks would the wire at the switch got pink black which i think is ign. 2 but can,t find color wire for ign. 1 hope for an answer
Old 01-25-2026, 05:32 PM
IGN 1 is the Pink with Black Stripe.
IGN 2 is Pink.
But the Pink with Black Stripe goes to a splice with a lot of other wires. Out of that splice one of the wires is the resistance wire that goes to the firewall connector.
The Pink wire also goes to that firewall connector, same number position on connector.
On the engine side of firewall the connector just has one wire come out at that position, which is Pink and goes to the coil. There is no external resistor wire or extra wire that goes to the coil.
That resistance wire I am not real clear on what color is, White with Orange and Purple stripes?
The coil gets lower voltage when in Run position, only 12 volts when cranking.
