Old 02-04-2026, 11:49 PM
daduck's Avatar
daduck daduck is offline
Default 1977 Grand Prix exhaust manifolds - will Firebird manifolds fit?
Grand Prix has a factory Pontiac 400 with 6x heads,
Firebird Central has Ram Air D-port exhaust manifolds but does not list Grand Prix as compatible.
I am going to call them but wanted to ask the experts here first.
I am not at all familiar with Firebird fitment or clearance issues compared to Grand Prix.
I plan to replace the entire exhaust system so the downpipe flanges on the Ram Air manifolds being different from stock it is not a problem.
TIA,
Dave
Old 02-09-2026, 11:57 AM
craig santry craig santry is offline
i have a 1975 grand am 400 and wanting to know the same thing. looking to put shorty headers on
Old 02-09-2026, 05:30 PM
unruhjonny's Avatar
I'd suggest starting this way;
if you still have your original manifolds, check the configuration, and if they are shared with the F-body;
if they are the same, odds are you can use them.
If you have a center dump drivers side exhaust manifold, then those RA manfolds will not work.
1970 Formula 400
Old 04-10-2026, 12:00 PM
Iggy Iggy is offline
I put a set of Ram Air Restoration RAIII manifolds on my 1974 Grand Prix (2-1/2" outlet) and used the Pypes system and manifold pipes for a 1969-1972 A-Body. They fit well and only minor tweaking.
