Old 02-05-2026, 08:34 PM
BAMiller BAMiller is offline
Default seal and gasket kit for a/c case
Started my new project a 1978 Trans am I am looking for a kit with all the gaskets and seals to rebuild the Heater/a/c case with factory air. I found the actuator I need but I can't find the seal kit only for without air.
Old 02-06-2026, 06:47 PM
jerry455 jerry455 is offline
I ended up making any that I needed from foam tape. I have a 1976 that I redid the heater core last winter.
Old 02-07-2026, 07:33 PM
I guess that's what I'm going to have to do. The rubber seals on the doors are OK I just need the foam ones shouldn't be to hard I found some adhesive foam backed sheets on amazon.
Old 02-27-2026, 02:23 PM
HWYSTR455's Avatar
Classic Auto Air:
https://www.classicautoair.com/origi...to-air-family/
Scroll to bottom for factory air replacement parts. They also rebuild POA valves and other parts.
Old Air Products:
https://www.oldairproducts.com/
I believe our host may also carry the seals but haven't checked.
