Old 02-09-2026, 10:03 PM
cdnturboz cdnturboz is offline
Default Correct 1 1/8” Sway Bar Bushings
Have a 72 GTO - has the stock 1 1/8” bar and brackets - been having issues finding the correct bushings .
I ordered a set off rock auto (Delphi brand) and they are way too tall to fit in the bracket.
Tried a set from inline tube that was supposed to fit and they are too small for the bracket…
Am I missing something? Is there a brand somewhere that I can get the correct fit?
ID:	664837   Click image for larger version
1972 Pontiac Le Mans GTO
Old 02-10-2026, 01:53 AM
OG68 OG68 is offline
Difficult to find the correct ones as I went through the same thing you did with a 1 1/8" bar I found in a 70 GTO.
IIRC, I found some through an eBay Corvette vendor a few years ago.
Old 02-10-2026, 08:02 AM
67Lemons 67Lemons is offline
I’m worried about the same thing on my ‘72 with the factory bar, I have a set of Energy Suspension sway bar bushings but haven’t installed them yet.
1972 GTO
Old 02-10-2026, 01:18 PM
65madgoat's Avatar
https://www.inlinetube.com/products/inl13148?
1964-1977 GM A-body, 1967-1975 F-body, 1968-1974 X-Body Factory Exact 1-1/8" Sway Bar Bushing 2pc
If these truly don't fit I see several different molded Corvette ones for sale out there.
https://www.mamotorworks.com/corvett...bushing-46795?
https://www.corvettepacifica.com/pro...h-each-68-82/?
Old 02-10-2026, 06:08 PM
Those are the exact ones pictured that I got from inline (the smaller ones)
Old 02-11-2026, 03:12 AM
locomotivebreath's Avatar
locomotivebreath locomotivebreath is offline
I put an 1 1/8th on my 68 last year and used the energy suspension bushing. Alls good .
When I wore a younger man's clothes
Old 02-11-2026, 05:07 PM
Thanks - maybe I’ll just buy a new bracket with the bushing then so I don’t have to mess around/waste money. Are there any better ones to buy ? Or can I buy anything for an abody with the 1 1/8” bar?
Old 02-11-2026, 08:25 PM
65madgoat's Avatar
Yeah just buy this set and call it a day
https://www.inlinetube.com/products/inl15033?
Old 02-11-2026, 09:44 PM
70GS455 70GS455 is offline
I ran into this also. I ended up just cutting the tall ones down
Old 02-15-2026, 11:30 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Second gen Camaro bushings?
Skip Fix
