Well I went and started the pontiac today outside temp was a balmy 43. Lol. but I decided to start it anyhow just to see how to would run with the chock hooked up. Let it sit about 5 or so minutes and realized I'm not getting any air out of my dash vents. Well the heat sure does work in that car but the fan only works on two settings the 2 in the middle. I'm i on the right track that it's the blower motor.
77 pontiac lemans base coupe with ac |
I would suspect either the switch, wiring, or the blower resister, the 1st thing I would do is pull the connector off the blower resister and clean the contacts. It the fan works in 2 of the 4 positions I don't think it is the fan. The resister should not come into play for the high position just the the others, you could jump the power directly to the high position to bypass the resister.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 1971 Fiat 130 Coupe 3.2L SOHC V6, ZF 5-speed 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 05 Dodge Magnum 3.5L SOHC V6 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
