Old 02-16-2026, 11:31 AM
jeffputts jeffputts is offline
Default Aftermarket gauge pod recommendations
Hi All
as my judge does not have the rally gauges i do want to add the basics, oil, temp, voltage in a pod under the dash. I want to run all electrical and not have the possibility of an oil line leaking in the cabin.
With so many options out there what does everyone like or had good luck with that matches close to the era?
Old 02-16-2026, 03:38 PM
Another option:
Old 02-16-2026, 04:23 PM
Another option:
i thought about the pillar mount as well, don't want to put any holes in it though, at least under dash i figured if it were to be removed you wouldn't see the screw hole
Old 02-24-2026, 05:54 PM
ended up buying a set of Marshall Instruments COMP II's for OIl pressure, coolant temp and voltage. will mount under the dash, they seem to look the most period correct
