Old 02-16-2026, 11:41 PM
74SDformula's Avatar
74SDformula 74SDformula is offline
Default What Is This Muncie 4-Speed Out Of?
I think this decodes as a 1972 M20. Based on the partial VIN, what would this transmission have been out of?
ID:	665158   Click image for larger version
ID:	665159   Click image for larger version
ID:	665160   Click image for larger version
Old 02-17-2026, 06:48 AM
Held for Ransom's Avatar
S = Corvette
So long, farewell.
Old 02-17-2026, 11:28 AM
Thanks, HfR!
Old 02-17-2026, 12:05 PM
oldman66gto's Avatar
oldman66gto oldman66gto is offline
Default HELP....Muncie M20 4Speed
Hi,
Saw this post and I too, need some help on decoding a Muncie 4-speed.
Pics attached, and THANKS for the help.
I just came out of my '66 GTO, when I put in a Tremec TKX
Trans case#3885010
Side plate #3884685
Tail shaft# 3846429
ID:	665166   Click image for larger version
ID:	665167   Click image for larger version
ID:	665168   Click image for larger version
Old 02-17-2026, 12:39 PM
unruhjonny's Avatar
Posting to help members in the future;
The following image has two distinct stamped codes;
One is what might be called the transmission ID code, the other is the partial vin to verify it as being original equipment (for warranty purposes).
P2D14A = tranmission ID code
P = Muncie-4spd (source plant)
2 = model year (1972)
D = month of assembly completion (April)
14 = date of assembly completion
A = gear set (wide ratio "M20"; IIRC B/M21 & C/M22)
12S828288 = partial vin code
1 = Division code (Chevrolet)
S = assembly plant code (previously mentioned as Corvette; N/Norwood; Z/Fremont; ect)
(last 6 digits) = final six digits of vehicle vin number
I hope this helps
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
Old 02-17-2026, 02:05 PM
Thanks for the information.
In Post#4, below yours, can you help explain how to decifer the other numbers, off the trans case, the side plate, & the tail shaft?
I am totally new at this as far as being able to know what the various sequences of numbers represent on each of the componet pieces.
Thanks again for helping an ol guy get educated!! This is more complex than being in "school"!
Old 02-17-2026, 02:13 PM
This is one site I use.
https://5speeds.com/muncie2.htm
Old 02-17-2026, 09:42 PM
WOW! Lots of information there.
Thank you so much.
I printed all of it to have as a reference.
Allan
Everything points to a '66-'67 , which is what previous owner said, & also gave me receipts for the parts on the rebuild. Done about 18 months ago, and only driven maybe 1,000 miles.
My plan is to sell it, since I got the Tremec, but wanted to be able to give a buyer, the correct information about it.
Thank so much for the help, it is greatly apprecited!
Old 02-18-2026, 01:51 PM
unruhjonny's Avatar
those other numbers are casting numbers;
They were used at the foundry to identify the part;
Post casting, all parts needed finish machining.
Muncie part numbers are great to identify if a transmission has been apart.
1970 Formula 400
