Old 02-18-2026, 06:59 PM
Shiny Shiny is offline
Default Exhaust Pipe Cutting Tool?
I want to cut off some silly-looking "too large" exhaust tips that were welded on and replace them with something less silly.
Do exhaust pipe cutters like this work? Not sure I can find them as a "loan a tool" so want to know if they actually make the job easy before I buy one.
Mike
Old 02-18-2026, 07:14 PM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Mike
That looks like a cast iron pipe cutter. If so, I don't think it will cut steel pipe
Old 02-18-2026, 07:37 PM
Good warning, thanks.
I have zero experience with tools for cutting cast iron pipe or exhaust pipe but see this style listed online. If I can find one in the parts store loan-a-tools I have nothing to lose by trying but don't want to buy one if it won't make the job easy.
Here's an example:
Cutter on Jegs
Old 02-18-2026, 07:42 PM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
Sawsall, fine tooth metal blade. Neater than cut off wheel on a grinder.
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
The Following User Says Thank You to hojs69 For This Useful Post:
Old 02-18-2026, 07:43 PM
dhcarguy's Avatar
I never saw one of those, but by the Jegs Pictures , looks like it will work with the pipe OFF the car
Old 02-18-2026, 07:51 PM
hojs69's Avatar
I have one of those also. They work (slower) and can be utilized on the car. One rotates / swings them back & forth.
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
Old 02-18-2026, 08:03 PM
grivera's Avatar
grivera grivera is offline
Those work, but are slow AF and distort the pipe a bit. The one I used was from AutoZone rental tools.
Will Rivera
Old 02-18-2026, 08:33 PM
sdbob sdbob is offline
Sawzall here.
Old 02-18-2026, 09:30 PM
72projectbird's Avatar
They do work, although they'll take a little time to cut through. You can use them under a car in tight spots where getting a sawzall or cutoff wheel might not fit.
It'll work. Or use a sawzall if you have one.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 02-18-2026, 10:00 PM
MatthewKlein MatthewKlein is offline
Mike
Got a cutter like that from Mac tool truck. Can't remember if it's Mac brand or not. It does work amazing. Did not expect it to.
Old 02-18-2026, 10:35 PM
Thanks all!
Sounds like the tool works so I'll check with Autozone.
Sawzall is a good backup plan if Autozone doesn't lend it or it proves to be less than wonderful in my hands.
Mike
Old 02-18-2026, 11:57 PM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
I was cutting an exhaust pipe on my LeMans around Christmas and forgot the first rule of using a sawzall....Protect your knuckles! When that saw bit.... I remembered!
Karl
The Following 3 Users Say Thank You to 72LuxuryLeMansLa. For This Useful Post:
Old 02-19-2026, 02:15 AM
Verdoro 68's Avatar
I usually go with a fine tooth sawzall as well.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 02-19-2026, 10:31 AM
VCho455's Avatar
VCho455 VCho455 is offline
Just keep in mind if the parts store rental tool doesn't seem to be working it may be worn out or abused and not working correctly.
Good luck.
Old 02-19-2026, 05:42 PM
Schurkey Schurkey is offline
I have this one, from Lisle. It is now obsolete, but select replacement parts can still be bought from Lisle while the supply lasts.
https://www.lislecorp.com/specialty-...ut-cutoff-tool
Claims to be strong enough to slice open McPherson strut housings.
Like anything with a cutting blade, when the blade goes dull, they don't cut well. The one you have pictured should cut wonderfully...if the blades are sharp. But I don't see a way to replace dull blades without replacing the entire chain. Works on the same principle as a single-cutting-wheel tubing cutter for fuel and brake tubing...which is also most-commonly steel.
Old 02-19-2026, 06:57 PM
67Lemons 67Lemons is offline
I’ve had the Snap On version of this cutter in my box since the late 80’s, it certainly works but the cuts aren’t as clean as a sawzall and it works best when it can be spun at least 180 degrees so it’s not good in tight areas.
https://www.speedwaymotors.com/Power...yABEgL5HvD_BwE
1972 GTO
Old 02-19-2026, 09:09 PM
This looks much nicer. Only gripe with the chain cutter is having to hold constant pressure. Its a nice forearm workout
Old 02-24-2026, 08:56 AM
HWYSTR455's Avatar
There are ratcheting ones too, but a little more money. Shop it, can find them under $100.
This is the first one I found searching to give an example:
https://www.misterworker.com/en-us/v...ipe/91045.html
The one I have is a little more, came with extra cutting wheels, though I bought some from Grainger that are better.
Take your time and don't crank it down too tight and they work well. They work in tight spaces too.
Old 02-24-2026, 09:00 AM
HWYSTR455's Avatar
The chain type 'work', but the blades go bad pretty quick. They are good for about 3-5 cuts and then you will be cussin'.
Old 02-24-2026, 10:39 AM
burd burd is offline
Use a metabo
