Old 02-27-2026, 05:11 PM
robg8r's Avatar
robg8r robg8r is offline
Default 400 is sitting at an angle...tilted towards the passengers side
I have a mid 70s block in my 69 lemans and my block is sitting at a weird angle to the passengers side. i think i am going to have to try changing engine mounts with an adaptor to fuss with also. https://www.ebay.com/itm/27156129626...019c86a02ff90a
Old 02-28-2026, 09:15 AM
graygator graygator is offline
Just last week, I replaced the passenger side engine mount on a 1974 455 in a 1969 Lemans. I also added a 3/16" thick shim matching the frame side bracket. Before the engine was tilted 2.5 degrees to the passenger side and the long tube header was much closer to the ground. Afterwards the engine was at a 0.5 degree tilt and I gained about 3/4" ground clearance on the passenger side header. Car was up pretty high on wheel cribs in the front and jack stands under the back. And I couldn't use my engine hoist due to the car's positioning in the garage. So I very carefully used a floor jack and a block of wood on that side of the engine. It was tight but it worked. See pictures in other thread. Purchased engine mount and shim from AMES.
https://forums.maxperformanceinc.com...d.php?t=884158
Kent R.
Old 02-28-2026, 12:20 PM
robg8r's Avatar
Thanks Graygator!!! I have plenty of room as I have regular exhaust manifolds.
I will give it a try. Thanks again and GO GATORS!
