Old 03-02-2026, 03:54 AM
dataway's Avatar
dataway dataway is offline
Default Junk carb parts needed
I've got this crazy side project of building an electronic servo controlled choke for 702/704 carbs. I'm not a carb guy, so I don't have parts lying around. I need a Quadrajet center section with the choke parts attached. It can be total junk but with a good choke plate, rod, and that mess of stuff that goes between the choke stove and choke plate
Only Qjet I have is installed on my GTO and I need to make many, many accurate measurements which would be a nightmare to do on the car.
BTW, the OEM choke on the 704 I have installed on my 68 works fine so far, this project is just a lark, just to practice my Arduino programming and 3d printing.
Plan is to be able to control the choke position based on the temp at a temp sensor placed any place on the engine you want, or to be able to dial up a choke position using an over-ride knob inside the car.
Old 03-02-2026, 10:48 AM
Mr. G Mr. G is offline
PM sent.
The Following User Says Thank You to Mr. G For This Useful Post:
