73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 03-05-2026, 05:51 PM
Flashflood Flashflood is offline
Send a message via AIM to Flashflood Send a message via MSN to Flashflood Send a message via Yahoo to Flashflood
Default Edelbrock avs2 1906 idling way high
I've been trying to hunt this I've got edelbrock avs2 1906, and it's idling high like 3000 rpm. I've got the electric choke hooked up to a good 12v volt and it still idling the same. New throttle cable and bracket. I'm at a loss. All vacuum ports are plugged and I can't hear anything. What could be causing this 77 pontiac lemans
Old 03-09-2026, 12:47 PM
Mr. G Mr. G is offline
Have you tried running it with the throttle cable disconnected from the carb to ensure that the cable is not holding the throttle open some?
Old 03-16-2026, 10:24 PM
If the throttle plates are actually closing all the way, and they may not be as you have a non stock carb on the engine. You probably have a big vacuum leak. I would suspect the carb base gasket to intake manifold.
Is there any adaptor plate mounted between the carb and the intake manifold?
Old 03-18-2026, 06:22 PM
I got this figured out to. I was idiot for not realizing the brake booster wasn't plugged so after taking care of that starts just like an efi car.
The Following 2 Users Say Thank You to Flashflood For This Useful Post:
Old 03-19-2026, 09:44 PM
Glad it was something easy and cheap! I have done almost the same thing myself, I had left the Trans vacuum modulator line off.
