Old 03-11-2026, 08:04 PM
rdk rdk is offline
Default tie rods
does anybody know the lengths of the inner and outer tie rods for a 1969 Grand Prix? the technician says it looks like I have four inners, they are all about 8 5/8 inches long, and he says the outer are too long, but the outer Ames lists are about 9 1/8 inches long. thank You for your time
Old 03-12-2026, 08:00 PM
Burgess's Avatar
Burgess Burgess is offline
My '72 inners measure 8 3/4", one outer is 9", the other about 9 1/8" or slightly longer. I'm not sure what has been changed though. The couplers are 4" long.
Old 05-23-2026, 07:28 PM
1969GPSJ's Avatar
1969GPSJ 1969GPSJ is offline
Default GP Outer Tie Rod Ends are apparently different from the A body cars.
I am discovering the same issue. The GP outer tie rods are vastly different from the (true) A-body cars. which is just about the only significant steering and suspension part that is really different. The Center links and inner tie rods are the same. So is the idler arm, pitman arm, and steering box. The outer tie rod ends for the GP are very expensive(well over 150 each), and I guess I will just have to bite the bullet and buy them. https://www.rareparts.com/RP25500A-2...iac-Grand-Prix OR https://www.kanter.com/products/stee...d5301243390cb7
