Old 03-13-2026, 08:59 PM
Tim Corcoran's Avatar
Default Doug's Headers
I installed my new Doug's headers and have a couple questions.
1. By installing the small extension will it have any effect on performance. I know the purpose of the extension is so you can attach exhaust in a street car.
2. For maximum vacuum exactly where to install the evac tube in the collector.
I have seen some posts that they cannot install the full size filter with Doug's headers but I have plenty of room to remove the full size filter with 1-7/8 round port.
ID:	666236   Click image for larger version
ID:	666237   Click image for larger version
Tim Corcoran
Old 03-13-2026, 10:04 PM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
I'm running the same setup on my 67 Firebird but I don't have a evac tube so I can't help you there. Do you really need it?
67 Firebird Convertible
Old 03-14-2026, 12:45 PM
Its the next best thing to a vacuum pump. It sucks out the blow by and creates a slight vacuum. Prevents leaks and improves ring seal. The system works pretty good and I have used it for many years. It does not work with mufflers only open headers.
Tim Corcoran
The Following 2 Users Say Thank You to Tim Corcoran For This Useful Post:
Old 03-14-2026, 01:37 PM
76TA462 76TA462 is offline
Not exactly the same set-up but close enough. I run shorty headers though. My evac is after the resonator (O2 before). If I hadn’t used the resonators I would have tucked it in a bit closer but probably same effect. The evac has been on a few years. Very happy with the results.
ID:	666263   Click image for larger version
Name:	evac and sensor.jpg
Old 03-14-2026, 06:40 PM
dv657172's Avatar
dv657172 dv657172 is offline
Here is my Evac tube setup. Definitely made a difference on reducing crankcase pressure after they were installed correctly.
It is very important to have the correct angle and depth of the tube in the header. As far as I recall Moroso recommends a 30 degree angle and the tube cutout which creates the vacuum should be at a 1/4" depth.
ID:	666275   Click image for larger version
1965 GTO Cameo White, Red Interior - 389, ST300 numbers matching
1965 GTO Black, Black Interior "Post" car - 389, M-20 numbers matching
1965 GTO Silver, Black Interior 100% dedicated drag car w/1968 400(461), 16x Heads, TH400, 3.90 9" Rear 1.656 60' 7.566 90.057 (1/8th)
1971 GTO Black (orig. Quezal Gold), Gold Interior - 400, TH400 numbers matching
1972 GTO Cardinal Red, Black Interior - 455, TH400 almost numbers matching
Old 03-14-2026, 06:56 PM
Mike Davis's Avatar
My evac tubes are 2 inches back from collector flange at about a 30 degree angle approx 3/4in into the collector. I run a 3.5in system with x-pipe and dynomax ultra flows turned down at rear axle. The evac will work fine with free flowing or race mufflers.Big thing is to make sure the breathers fit in the grommets really tight and there are no leaks. I rtv the grommets to the valve cover and also use a ball peen hammer to tap the breather tube a little to expand. I have also found using hose clamps helps. My car runs faster with the X-pipe and evac than it does open headers or extensions. Which is surprising considering the exhaust is almost 65 lbs.
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
The Following User Says Thank You to Mike Davis For This Useful Post:
Old 03-14-2026, 07:16 PM
Agree with Mike on the fitment of the breather. I ended up using the Moroso positive locking breather (oil separator for some) 68785. Also, and not necessary, but I had to change from the standard Moroso oil check valve at the exhaust because especially at idle it rattled a lot (didn’t know what the rattle was at first – thought another gremlin popped up). I changed to the Moroso oil check valve 23875 and all good.
Name:	locking breather.jpg
The Following User Says Thank You to 76TA462 For This Useful Post:
Old 03-14-2026, 07:42 PM
dv657172
What is the purpose of the extensions after your collector?
Tim Corcoran
Old 03-14-2026, 09:03 PM
dv657172's Avatar
The header extensions are supposed to increase power and torque. I have never checked with them on vs. off to be honest but thats what the guy who was a very serious street racer in South FL recommended after I destroyed the 3" Pypes full exhaust system along with a driveshaft on my first track outing ever. I also had a very memorable 180 rotation at about 1,000 feet thanks to the trans fluid but no damage. Lesson = dont use nearly 60 yr old stock upper control arms. I'm a rookie at the racing stuff.
Here's some commentary.
https://www.yellowbullet.com/threads...sions.1182330/
Old 03-14-2026, 09:48 PM
Here is a very interesting video on the placement of the venturi tube in the collector for an evac system. This guy did some very cool testing and I was surprised by the result with regards to how to place the tube in the gas stream.
https://www.youtube.com/watch?v=uL4rnN-Sr9M
Tim Corcoran
