Old 03-14-2026, 05:27 PM
CraigG.'s Avatar
CraigG. CraigG. is offline
Default Line lock installed question for a drum brake 1970 Tempest or drum brake A Body 70-72
Hey everybody - hopefully you are having decent enough whether to be safe from tornadoes and hail.
For a 1970 drum brake Tempest front brake line lock install:
Question: can you install a line lock in series from the master cylinder to the inlet on the pressure differential switch block?
We are not concerned with the brake warning light operation.
Thank you,
Craig
