Old 03-16-2026, 02:05 PM
dv657172's Avatar
dv657172 dv657172 is offline
Default Rear Sway Bar issue
65 GTO dedicated racecar
Car has had a swaybar that runs directly under the rear housing since I bought it which requires jacking the car up by the side frame rails in the rear rather then under the rear end which is a pain. (see pic - taken at end of race season, all cleaner now fyi)
Whats a good solution to this issue? Anti-roll bar? Car doesnt make a ton of horsepower yet but hopefully increasing it in time
1965 GTO Cameo White, Red Interior - 389, ST300 numbers matching
1965 GTO Black, Black Interior "Post" car - 389, M-20 numbers matching
1965 GTO Silver, Black Interior 100% dedicated drag car w/1968 400(461), 16x Heads, TH400, 3.90 9" Rear 1.656 60' 7.566 90.057 (1/8th)
1971 GTO Black (orig. Quezal Gold), Gold Interior - 400, TH400 numbers matching
1972 GTO Cardinal Red, Black Interior - 455, TH400 almost numbers matching
Old 03-16-2026, 05:45 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
How about this?
https://www.proeagle.com/products/floor-jack-extensions
Skip Fix
Old 03-16-2026, 06:21 PM
dv657172's Avatar
The issue isnt the height its that the swaybar runs directly under the rear diff and to try and jack up the car via the diff you would bend or at least stress the sway bar as there is a gap between the bar and the diff.
Old 03-16-2026, 08:22 PM
Put a wood block between the bar and the differential or just remove the bar. I dont think the bar does much for a drag car.
Old 03-16-2026, 10:20 PM
Mike Davis's Avatar
I have a BMR anti roll bar on my 65 and 66. I use a block of wood between the bar and housing most of the time. The BMR has 2 clamps on the axle tubes and 2 links that go to the frame. When I am at the track I usually just out the jack under the bar. I haven't noticed any deflection or bending.
Does your bar bolt to the Lower Control Arms? Does the car leave level?
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
Old 03-17-2026, 12:42 AM
ANDYA ANDYA is offline
I have the same issue with my 65 GTO. I have a dedicated block of wood for this purpose. In my case a 2x4 is too thick. I believe it’s a piece of 5/4 with some blue tape on it so I can find it easy.
Old 03-17-2026, 06:57 AM
dv657172's Avatar
Thanks for the wood idea guys. Will definitely work on that.
Mike - Welcome back to the board. The car does leave level and the bar is bolted to the control arms which are boxed.
Old 03-17-2026, 08:26 AM
Mike Davis's Avatar
Thanks for the welcome back.
When my 66 had a bar bolted to the lowers I could not get it to leave straight or level is why I was asking.
Sounds like a block of wood will fix the issue.
421 CID
Old 03-17-2026, 01:33 PM
Skip Fix's Avatar
I was thinking the narrow tube spacer could get the rear around the bar.
Skip Fix
Old 03-17-2026, 04:33 PM
dv657172's Avatar
Skip Fix - thanks for the alternative. It might work but will give the block of wood a try first
Old 03-17-2026, 05:14 PM
Skip Fix's Avatar
I think the block would be better and cheaper!
Skip Fix
Old 03-18-2026, 11:12 AM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
I always wondered why there wasn't a horseshoe like item that would slip through the swaybar, then spin it and you could push on this and it would only touch the rear diff and jack.
I guess you could do this with the wood block, slot it, slip through, spin it then you push on the bottom of the block and top of block pushes on rear diff and not the swaybar.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
The Following User Says Thank You to GOAT8U2 For This Useful Post:
Old 03-18-2026, 04:34 PM
We all do it but I wonder at the wisdom of jacking by the diff?
I gave thought to putting a drain plug in the floor of the casting but not worth the potential for issues.
On a side note was gassing up here in NM and a Tundra pulled in and made a hell of a bang - like it hit a bollard. She pulled forward and even louder bang. Broken diff? She just came from the mechanic for brake work - maybe FOD in the diff?
