OHC-6 TECH Over Head Cam projects, questions and advice.
Old 03-16-2026, 04:29 PM
scotty54's Avatar
scotty54 scotty54 is offline
Default Temp Sending Unit
More newbie questions about my 1968 Sprint. It appears that I have two temperature sending units but I don't understand why? One is on the water neck and the other in the block on the opposite side. I did not trace the wires to see where they go.
ID:	666403   Click image for larger version
Old 03-16-2026, 05:29 PM
The one in the second picture is the stock location on the head, not the block, I have never seen one mounted on the thermostat outlet before, interesting. I suspect you have a gauge and an idiot light hooked up. Not a bad thing in my opinion. I have modified the thermostat housing with a nipple to send warm coolant warm a base plate I had made that bolted to the bottom of the intake manifold, where the exhaust manifold normally attaches. I did this on an engine with headers, and it helped with cold weather operations. I used to drive my cars until snow actually fell, so if the temps were below freezing, it would help the engine run and idle better after the engine warmed up.
Old 03-16-2026, 05:35 PM
76TA462 76TA462 is offline
I could be wrong on this. The connection on your water neck looks like the one I had that was situated just to the side of my water neck on my intake and went to my dash cluster. The other one looks similar (not exact same) to a second temperature sending unit when I added an AutoMeter gauge. I wonder if your car had a second gauge at some point. Chasing that wire would be worth it.
Old 03-16-2026, 07:20 PM
Jeff Hamlin's Avatar
Looks like an old Chevy Water Neck
Old 03-21-2026, 06:36 PM
scotty54's Avatar
I do have a gauge (inop) and just realized I do not have a functioning idiot light either. Time to chase wires. I like the idea of both but the thermostat housing is unattractive. I have a stock unit and may rely on the gauge alone.
