Old 03-16-2026, 06:28 PM
242177P's Avatar
242177P 242177P is offline
Default Old draw through (SBC) on Craigslist
Not mine. Suspect it's supposed to use a 301T Q-Jet.
https://seattle.craigslist.org/sno/p...917544950.html
Old 03-25-2026, 08:48 PM
Pontiac Performance Author
looks like a Marten turbo system with a bunch of parts missing
The Following User Says Thank You to KEN CROCIE For This Useful Post:
Old 04-29-2026, 10:03 AM
Joe-Touring Joe-Touring is offline
Very interesting, does the carb sit on the manifold and connect to the turbo via those flanges and cast aluminum ducting?
67 LeMans, 326, M20, 3.31 12 Bolt
Old 05-13-2026, 11:39 AM
the 6 rectangular ports under the carb pad have flapper valves (like reed valves on a 2 stroke M/C. this allowed the carb to run normally when not making boost When boost started to rise, the pressure would close the valves The kit is missing the Pass. side exhaust man. where the turbo was mounted.
