Old 03-24-2026, 12:25 PM
dv657172's Avatar
dv657172 dv657172 is offline
Default Transbrake Question
I am running a TCI TH400 trans (212300) with a Reverse Valve Body and using a TCI Transbrake (221300)
When I backup should I being pushing in the Transbrake Button while in Neutral to do so or can I use Reverse gear?
I have been using reverse gear in the past but recently read its bad to do. I asked TCI via their tech form giving them the same info and the answer I received was "it would be determining on your valvebody". Not very helpful or written well.
Thanks for always answering my basic questions
1965 GTO Cameo White, Red Interior - 389, ST300 numbers matching
1965 GTO Black, Black Interior "Post" car - 389, M-20 numbers matching
1965 GTO Silver, Black Interior 100% dedicated drag car w/1968 400(461), 16x Heads, TH400, 3.90 9" Rear 1.656 60' 7.566 90.057 (1/8th)
1971 GTO Black (orig. Quezal Gold), Gold Interior - 400, TH400 numbers matching
1972 GTO Cardinal Red, Black Interior - 455, TH400 almost numbers matching
Old 03-24-2026, 02:37 PM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
i have never seen a th400 that required push button for reverse. (only pro tree powerglides). the ones i have owned you just put the shifter in reverse independent of the trans brake button. infact make sure you can not hit the button when you are in reverse.
Old 03-24-2026, 03:29 PM
Dragncar Dragncar is offline
I run a T400 with aluminum J & W trans brake valve body and hitting the button is required for reverse. Its the way it was made, no issues. Works great.
My shifter needs to be in reverse too for it to work while I hit the button.
The Following User Says Thank You to Dragncar For This Useful Post:
Old 03-24-2026, 03:34 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Not sure which TCI brake you have. When I looked up that number it was for the solenoid. Anyway, I have an old style TCI in my 400 and the instructions specifically said to use neutral and the brake button to go into reverse. If its a newer one that's different I don't know.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 03-24-2026, 04:42 PM
dv657172's Avatar
I guess I don't know either Jack unfortunately. This is the Trans we put in the car in 2012
https://www.tciauto.com/drag-race-th...v3Fk_xeT5af7jI
which uses the Transbrake Solenoid 221300 and a button on the dash. Have never had any issues although car only has about 60 1/8 mile passes on it.
Car pushed through the Transbrake on the line all 3 times we tried to make a pass this last weekend which got me to investigating transbrakes and saw the comments about reverse (although not related to this past weekends issue) thus the inquiry.
Old 03-24-2026, 04:50 PM
hmm my tci must have been old. i think i have whatever hutch sells in my car now it does not use the button for reverse
as far as puchong through thr line try increasing yur rpm before engaging trans brake, more line pressure
Old 03-24-2026, 07:16 PM
dv657172's Avatar
Thanks mysticmissile for the advice. I am going to check my line pressure just to make sure everything is in line plus have a baseline for future reference. Hopefully it was a low fluid issue. Read full after replacing the stall converter over the winter but discovered it was low after the second run. Added a quart but still pushed through the brake although not as bad. Needed another quart to get it to full back at home. Hopefully test the brake tomorrow.
Old 03-24-2026, 10:25 PM
SRGN SRGN is offline
Most modern brakes need to have the shifter in reverse and push the button to engage reverse. Some older units did need to be in neutral. My Griner equipped 400 had to be in reverse plus pushing the button.
Old 03-25-2026, 06:28 AM
chuckies76ta's Avatar
You really need to know what valve body is used in the Tranny. Strange TCI could not give you an answer. If you remove the tranny pan, there is usually a number on the valve body for reference. I just went to TCI website and was looking at Part # 221580 valve body, and could not locate the installation instruction. Hmmm, that's frustrating. Any wonder they can't help you.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick.
Best so far 9.95@135 mph. 1.39 60 ft.
468 with KRE D-ports, Doug headers, 3" Exhaust
950 Quickfuel.
Old 03-26-2026, 07:27 AM
dv657172's Avatar
Thanks for all the information and thoughts guys.
Will check what Valve Body the trans has the next time the pan is off (hopefully not for a while) to be better informed.
Definitely wouldn't buy another TCI trans in the future given their lack of tech help and knowledge of their own products, at least in this experience. Guess I will just keep using Reverse gear for backing up for now.
On a somewhat related note, after getting the transmission to the correct fluid level the Transbrake did hold the car in my driveway at 4,000 rpm on 2 seperate tests.
The Following User Says Thank You to dv657172 For This Useful Post:
Old 06-01-2026, 04:54 PM
dv657172's Avatar
Just a follow up
Running a TCI TH400 trans (212300) with a Reverse Valve Body and a TCI Transbrake solenoid (p/n unknown).
It would appear that it is best to only use Reverse via pushing in the Transbrake button while in neutral to backup.
At idle my line pressures were basically 205 including when on the Transbrake except for Reverse which was only 75 psi. At 2,000 rpm my line pressures were 215 including the Transbrake and reverse was 180. TCI recommends between 180-200 at 2,000 rpm.
From a line pressure standpoint, using Neutral and engaging the Transbrake button appears to be the best for backing up. There was an explanation on Yellow Bullet as to why Reverse at idle is low on a TCI but now I cant find it.
Old 06-01-2026, 05:16 PM
CraigG.'s Avatar
CraigG. CraigG. is offline
I have Old TCI trans brake 1990's and I would like to know if there is a difference as I just put it in neutral or reverse - I don't pay attention.
Thanks, Craig
Old 06-03-2026, 01:53 PM
73LeMans's Avatar
73LeMans 73LeMans is offline
A friend asked FTI about this. Was told if its a sportman type brake, you can use reverse gear. If its a pro brake, use neutral and the button. It all depends on fluid volume through the brake.
I always use the gear. Not sure who makes the brake I'm using, but its over 20 years old and never gave me a problem.
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....and 2023....and 2024.....and 2025.....who am I kidding? there will be no 9s with this engine!
>>My 73 Build thread
Old 06-03-2026, 04:54 PM
You want a trans brake or any T400 PG stuff. Give J& W a call. My brake has been flawless. A lot of the aftermarket drums ect came from them and were copied by other US manufacturers.
The owner is great, you can call him and ask him trans building questions and always tells me call him back and he will help.
He even helped me with questions about my center support, direct and forward drums that did not come from him. Great guy, he knows A LOT and is willing to help.
