Old 03-26-2026, 08:25 PM
TommyGunn's Avatar
TommyGunn TommyGunn is offline
Default Couple questions
Hey all thanks for the warm welcome. I've got a couple questions I'm hoping you can help me with. How can I verify it is a 455. No tags or stickers under hood. Can't read side of block unless I start removing things which I'm not ready to do. Vin has a W in it and I read that means 455?
Second question- did i really buy a 52 year old car with less than 8000 miles on it? Following pics- spark plug- looks pretty 70ish. Spark plug wires- do last 2 numbers correlate to date of manufacture? If so they are 1974 wires on one side and 1979 wires on the other? Seems like they would have been replaced since then. Pedals- accelerater pedal looks pretty new, brake pedal does look worn but mainly on one side? Any other ways to tell mileage? Sorry for the long post and thanks in advance!
The Following User Says Thank You to TommyGunn For This Useful Post:
Old 03-26-2026, 08:28 PM
TommyGunn's Avatar
Odometer
Old 03-26-2026, 08:31 PM
TommyGunn's Avatar
Spark plug and wires
ID:	667040   Click image for larger version
ID:	667041   Click image for larger version
Old 03-26-2026, 08:33 PM
TommyGunn's Avatar
Pedals
ID:	667043   Click image for larger version
Old 03-26-2026, 08:48 PM
SRGN SRGN is offline
Originally Posted by TommyGunn View Post
Odometer
Given the alignment of the numbers, it's likely been around once. Probably 108k miles.
The Following User Says Thank You to SRGN For This Useful Post:
Old 03-26-2026, 08:50 PM
TommyGunn's Avatar
That was my initial guess as well- but these other things have me wondering. Good point about the alignment being off. Hadn't thought of that.
Old 03-26-2026, 09:30 PM
gtospieg gtospieg is offline
No way that brake pedal is only 8000 miles...the stainless is worn through.
Old 03-26-2026, 10:16 PM
TommyGunn's Avatar
Agree. It's just odd the other things.
Old 03-26-2026, 10:29 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Should be easy to see a 455 cast into the block on the drivers side to the rear of the fuel pump.
Old 03-26-2026, 10:31 PM
If it runs and looks like it has less miles than indicated, just be glad that you bought a well maintained car. Not easy to find anymore. My advice is to enjoy the car and don't worry about it. Continue maintaining the car well, and you will have some fun with it.
Old 03-26-2026, 10:35 PM
Shiny Shiny is offline
Were plug wires labeled with metric units in 1975? I suspect not but just a guess...
Old 03-26-2026, 10:44 PM
TommyGunn's Avatar
Thanks i will look there
Old 03-26-2026, 10:47 PM
TommyGunn's Avatar
Absolutely! Plan is to change plugs and fluids and belts and hoses this weekend- then go for a ride!
Old 03-27-2026, 08:22 AM
Half-Inch Stud's Avatar
Left of Dizzy, Look for iron post (indicates 421/428/455) cast in block's trans mount surface.
Otherwise, step on the gas pedal: if it gets up and goes, you'll verify.
Old 03-27-2026, 10:56 AM
77 TRASHCAN's Avatar
If you lay your hand on the drivers side of the block, and move it rear ward, you will feel the numbers. They may have dirt/debris on them.
On the passenger side the numbers are directly behind the dipstick tube, not quite as accessible...
I was surprised to see that your 75 has rectangular headlights. As a high schooler I remember seeing the first car with rectangular headlights. It was a 1976 Monte Carlo. Man, I thought that was cool.
One thing to think about. If you have any issues with smooth acceleration, you may need some carb work. Beware that in 1975 GM was trying some different modifications with the Quadrajet carb. I don't know if all of them were this different style (has to do with primary metering, you likely couldn't tell from exterior view). It's something to e aware of if you need carb work. The carb number is on the drivers side of the carb. A vertical flat area. Number is 7 or 8 digits, starts with a 70 or a 17
Shut it off
Shut it off
Old 03-27-2026, 07:34 PM
TommyGunn's Avatar
Great info- thanks!
Old 03-27-2026, 09:23 PM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
You can probably see it with a mirror. Here's mine where it shows it a 400.
67 Firebird Convertible
