This is a 68 Firebird Sprint restomod. New OEM style wiring harness plus a few accessories added. Trying to sort out an electrical gremlin and found this plug exiting the stock steering column. The column has a cruise control stalk but no other components. Could this be for the cruise control? I have a TSM but find the wiring diagrams lacking.
No idea on the plug but I'm curious about this sprint restomod definition
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
A 68 factory cruise control stalk only has three wires. Black, Blue and Tan. You have what looks to be an aftermarket (Rostra/Dakota Digital?) plug. Rostra schematic shown.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2015 Chevy Express ![]() 2024 Cadillac LYRIQ |
| The Following User Says Thank You to OG68 For This Useful Post: | ||
Thanks OG. That might be it. Never heard of Rostra but just looked them up.
And Turbo69 - frame off resto with a Global West front and rear suspension, Clifford intake with 3 Webbers, TH200 trans. Looks completely stock until you open the hood. |
4 pin Molex connector, check with the column manufacturer or cruise control manufacturer to see what they intended it to be plugged into.
It plugs into a second harness from the cruise control box. Usually located under the hood. But since you have Webers I doubt it's still there.
