Old 03-30-2026, 04:30 AM
dataway's Avatar
dataway dataway is offline
Default TH400 Modulator questions
So, last time I had my GTO out, one of the few drives I've made in it so far, it seems to shift pretty early.
It's got the original OEM modulator, which when tested with vacuum seems to operate as it should.
I was wondering, if I remember correctly, I think I put an extra fat, or possibly two o-rings on it because it was leaking a little bit. Would moving the modulator out (away from the trans) by the thickness of an additional o-ring effect the shift points? Seems like the vacuum pulls the plunger to the outside, so if the plunger was already moved out a tad by additional or fatter o-ring it would imitate a larger vacuum signal.
Also, would a tired spring on an old OEM modulator create shorter shifts?
I have an NOS Borg Warner unit on the way just in case.
Old 03-30-2026, 10:07 AM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Default Modulator
Agreed with two O rings I would say the valve would then think modulator is retracted
Farther into the body of modulator then it really is. That would mean early and softer shifts.
Gerry.
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds
The Following User Says Thank You to 68 Firebird For This Useful Post:
Old 03-30-2026, 07:03 PM
stevep's Avatar
stevep stevep is offline
Yes, 2 O rings would make it shift slightly softer and earlier
The Following User Says Thank You to stevep For This Useful Post:
Old 03-30-2026, 11:31 PM
dataway's Avatar
Thanks gents.
Old 03-31-2026, 07:41 AM
Half-Inch Stud's Avatar
Governor inner weights (and springs) control the upshift. Lighter weights and weaker springs for later upshifts.
Vac Mod has only a little effect on shift time, more like Line Pressure increase for shift firmness.
Was the 2nd Post but i see that my Post didnt stick.
Old 03-31-2026, 10:56 PM
dataway's Avatar
Well the shifts are bit soft too, I've got the standard Trans-Go performance kit, the least "performance" of the bunch I think. The whole trans is fresh, I rebuilt the entire thing, and it probably doesn't have 30 miles on it. So there could be a whole slew of issues I guess
Old 04-01-2026, 01:33 AM
kyle_blake's Avatar
kyle_blake kyle_blake is offline
get an adjustable one... ? its only for part throttle shifts.. not wot as i understand it.. i use adjustable on my th400 , has allen key
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane
Old 04-01-2026, 02:56 AM
dataway's Avatar
The NOS BorgWarner unit I purchased as a backup is identical to the OEM unit with the exception that the adjustment is not spot welded like the OEM unit.
And yes my soft early shifts are at around 2/3 throttle.
Old 04-02-2026, 02:06 AM
Schurkey Schurkey is offline
OK, it's been awhile. Been playing more with non-modulator transmissions lately. Maybe I've forgotten something.
WHY would an extra O-ring on the modulator have ANY effect on it's operation? The O-ring(s) slide into the case, they don't change the position of the modulator within the case. The modulator retaining fork-and-bolt end up in the same place with two O-rings as they do with one O-ring.
I have put double O-rings on every modulator, and every TH400 filter extension since Fido's great-great Granddoggie was a pup.
Old 05-15-2026, 05:07 PM
Bermudagto's Avatar
Bermudagto Bermudagto is offline
On this same subject...I did an engine swap and the edelbrock performer only has 1 tap for vacuum at the rear. I need it for Brake booster AND I need vacuum for my TH400 modulator. How can I split that off or is there an alternate vacuum source for the smaller 1/4" line that leads to my transmission? I understand transmission vacuum cannot be sourced from the carburetor. Thx
