Old 04-02-2026, 04:06 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Default Bought a '32 Chevy 5-window Deuce Coupe
Had a GTO since I was 16. Had many muscle cars and trucks. Closest thing to a Hot Rod was my '55 Chevy Sedan Delivery. I've always wanted a deuce coupe. I just picked this up last Friday. It needs a lot of work. But that's what I wanted. It came with a crazy amount of parts! I'm super excited to work on it and learn. So, I will be selling a pile of Pontiac parts to fund parts for this build. So, watch the high performance parts section if you need stuff.
The pic makes me realize that I need to straighten up. Ha.
The Following 5 Users Say Thank You to JSchmitz For This Useful Post:
Old 04-02-2026, 04:12 PM
JSchmitz's Avatar
It came like this. It came with a disc brake conversion kit. I put that on right away. Had to get those tall red spoke wheels off of the front! The body work need redone and more done.
How he bought it
ID:	667530   Click image for larger version
Old 04-02-2026, 04:13 PM
JSchmitz's Avatar
If you have '32 Chevy knowledge, or parts, please share!
Old 04-02-2026, 04:52 PM
That looks like a nice clean sheet to start with.
Old 04-02-2026, 06:36 PM
JSchmitz's Avatar
Thanks! Good enough. I think it would scare a lot of people off. Lol!
Old 04-02-2026, 06:55 PM
einstein's Avatar
einstein einstein is offline
Needs a Sprint 6.
The Following 3 Users Say Thank You to einstein For This Useful Post:
Old 04-02-2026, 07:17 PM
694.1 694.1 is offline
Big Time!
Still have my 1st Firebird
7th Firebird
57 Starchief
The Following User Says Thank You to 694.1 For This Useful Post:
Old 04-02-2026, 07:22 PM
SRGN SRGN is online now
I've worked on a few early Ford hot rods from that era. The fun part is, if you are doing a hot rod, you can put everything exactly where you want it It does work out a little cheaper if someone makes a chassis for it. You could also box and brace your current chassis and put a Mustang 2 front suspension on it with rack and pinion, then figure out if you want leaf springs or a 4 link out back. Order a catalog from Speedway, lots of parts in there, even saw a few things that I didn't know were made last time I looked through it.
The Following 2 Users Say Thank You to SRGN For This Useful Post:
Old 04-02-2026, 08:25 PM
JSchmitz's Avatar
I thought about a Sprint 6. Would be cool! It came with a fresh rebuilt '68 Camaro 250 6, rebuilt 700r4, and '55 Chevy rear. Motor and trans not fired up yet. The '55 rear supposedly out of 35k mile car. Appears to have 3.50ish gears based on turning the pinion test. The frame has been partially boxed. Also has a new crossmember for the 6 cylinder and trans. It has a drop front axle and disc brake conversion. All steering has been rebuilt. Stock '32 steering box feels tight and smooth. Has parallel leaf springs front and rear. Not gonna put huge power in the thing. Just a sorta mild SBC probably.
I have seen a lot of stuff at Speedway. Catalogue is a great idea. Thanks for the tips!
Learning curve just starting...
ID:	667541   Click image for larger version
ID:	667542   Click image for larger version
ID:	667543   Click image for larger version
ID:	667544   Click image for larger version
The Following User Says Thank You to JSchmitz For This Useful Post:
Old 04-02-2026, 09:42 PM
dv657172's Avatar
dv657172 dv657172 is offline
Congrats! That looks like a fun project for sure.
While I love the 32 Fords, the other brands were also very cool that year. I bought my cousins 32 Dodge DK coupe after he died in 2013 which he bought in 1972.
I remember sitting in the seat of that car in the mid 1970s as a kid in my grandmothers barn when it was yellow. I have been slowly giving it some of my own personality. It has a 1966 Chevy 327 with date matching "fuelie heads". Its not a little Duece Coupe though with a 122" wheelbase due to it originally having a 90 hp straight 8 engine from the factory.
1965 GTO Cameo White, Red Interior - 389, ST300 numbers matching
1965 GTO Black, Black Interior "Post" car - 389, M-20 numbers matching
1965 GTO Silver, Black Interior 100% dedicated drag car w/1968 400(461), 16x Heads, TH400, 3.90 9" Rear 1.656 60' 7.566 90.057 (1/8th)
1971 GTO Black (orig. Quezal Gold), Gold Interior - 400, TH400 numbers matching
1972 GTO Cardinal Red, Black Interior - 455, TH400 almost numbers matching
The Following 2 Users Say Thank You to dv657172 For This Useful Post:
Old 04-03-2026, 04:05 AM
einstein's Avatar
If the build so far accommodates that Chevy inliner, just plug and play. Online sixes bring a unique personality and song to the game.
Old rods with less common engines always stand apart from the never ending small block Fords and Chevies.
The Following User Says Thank You to einstein For This Useful Post:
Old 04-03-2026, 05:34 AM
JSchmitz's Avatar
That is a beautiful car! Thanks for sharing!
Old 04-03-2026, 05:37 AM
JSchmitz's Avatar
It is tempting to run the straight 6. Supposedly has a hotter cam etc. I just doubt that I'll be happy with the power.
I hear ya. Partly why I insisted on a Chevy. I'm a GM man all the way.
Old 04-03-2026, 08:03 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Looks like a cool project
Go fast, see Elvis!
Old 04-03-2026, 08:09 AM
Half-Inch Stud's Avatar
Nice Blue Body color. Front discs look great!
I'd be keen to use a late 60's wiring harness for familiarity and reliability, HEI on a PMD engine, preferring the OHC-6, then the 455, and as much overdrive you can get in the transmission and rear combo.
. Then a modern Factory stereo for the fidelity.
How about a tow hitch ?
Old 04-03-2026, 08:57 AM
moneypit's Avatar
moneypit moneypit is offline
Awesome car! Congrats! Build it, drive it, and enjoy! I like the dropped axle and disc brakes, looks good! I've always preferred that set-up versus the M-II and rack on open fender cars like yours. I run a M-II type on my 37, but I have fat fenders so you can't see it. Anyway, great car, enjoy!
37 Pontiac Sedan 455 700r4
94 Firehawk Supercharged 5.7 LT1 6spd.
71 GTO base 400 A/T
97 F250 7.3 turbo diesel
The Following User Says Thank You to moneypit For This Useful Post:
Old 04-04-2026, 12:12 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Why not keep it all Chevy and inline six? I don't recall the details, but I understand that the "late model" (1990's maybe?) 4-valve Chevy six has great power potential.
Old 04-04-2026, 06:28 AM
JSchmitz's Avatar
It's not out of consideration yet. I have a 90's 350 roller motor under the bench. So will likely use that. I am super curious about how this 6-cylinder would perform in such a light vehicle. But then there's the sound. Sixes just don't have the appealing V8 rumble. The six that came with it is from a '68 Camaro. Supposedly has 305 or 307 pistons. I'd have to look. The two extra, from the set, are in a box. Also supposedly has a HP cam. He's looking for the paperwork. I might try the machine shop also. Was built at Smith Machine Shop in Wichita KS. It's good to have free options!
Old 04-04-2026, 06:33 AM
JSchmitz's Avatar
Well crap! I guess I'm not talking to Smith Machine Shop.
Old 04-04-2026, 08:22 AM
That was the 4.2 liter DOHC that came is TrailBlazers - nice engine.
I do not think it has much of an aftermarket though.
