Old 04-08-2026, 01:50 PM
Terry M. Hunt Terry M. Hunt is offline
Default Will this solve the exhaust port paint burn off issue?
Looking at Eastwood Internal Exhaust Coating. Wondering if applying this 2-3 inches into each exhaust port from the exhaust manifold side would lower temps in this area enough to prevent paint burn off on the outer surface. Would using this product this way then result in the exhaust temps flowing into the exhaust manifolds, head pipes, mufflers, etc. to be higher than normal and perhaps higher than these parts are designed to withstand? Has anybody tried this?
Terry Hunt
"He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr.
Old 04-08-2026, 02:02 PM
rwfisher's Avatar
rwfisher rwfisher is offline
I think you’ll still see temps. that are high enough to blister the paint. What was recommended to me years ago by a noted Pontiac restorer was to not apply the engine paint to those areas you know are going to burn off. Instead, paint in those areas with Eastwood cast iron look high temp paint. This still looks like the paint has burned off but will be rust resistant and not show the gold tone of the burnt engine paint. Easily touched up with a brush if needed. This also works on the intake crossover if you don’t run that blocked off.
Old 04-08-2026, 02:13 PM
67drake's Avatar
67drake 67drake is offline
I have no clue. But it would be a great idea if it works. I’ve been painting my exhaust port and intake crossover area with header paint, followed up by engine color for years. It works OK. But if your idea works it might help keep the engine paint from burning off. So I’ll be watching this thread as I’m going to be putting an engine together pretty soon.
‘55 Catalina
Old 04-08-2026, 02:17 PM
JLMounce JLMounce is offline
I think it's eastwood that makes a very high temp silver engine paint that is known to do a decent job with this. Use that as the base coat over the exhaust ports, then paint your typical Pontiac Blue engine paint over that.
With that said though, I don't mind the paint burning on exhaust myself. When I see Pontiacs at shows, events etc and they've still got a Pontiac engine, I always look at the exhaust ports and I can tell who actually drives their cars.
-Jason
1969 Pontiac Firebird
The Following User Says Thank You to JLMounce For This Useful Post:
Old 04-08-2026, 04:23 PM
VCho455's Avatar
VCho455 VCho455 is offline
I've been painting the ports first with two coats of silver BBQ paint and then two coats of the metallic blue engine color for years.
Old 04-08-2026, 06:37 PM
Formulajones's Avatar
I've taken that a step further but with a different product.
For many years I've coated that area with POR15 cast iron paint but I don't leave it that way. After that cures I then cover it with the proper engine color paint when I paint the rest of the engine.
This has lasted me years, I very rarely have to go back and touch up the blue paint. In fact I've put at least 60,000 on my own since this was done and I think maybe I've went back and lightly touched it up twice. I've used this method on builds I've done for others with good results.
https://youtu.be/XqEydRRRwqE
Old 04-08-2026, 07:35 PM
I’ve tried all the gimmicks over the past 40 years, but none of them worked. Some briefly prolong the time before the paint fades out, turns brown, then turns to white ash., but that always seems to be the outcome. I would try the internal exhaust product if I could convince myself that I wouldn’t wind up setting the car on fire from the unexpected red hot glowing exhaust system that might occur. There must be somebody who has tried this, but low odds of ever discovering who they are I guess.
Terry Hunt
Old 04-08-2026, 07:59 PM
Cardo's Avatar
Cardo Cardo is offline
I've done it with the Eastwood product. It still burns the blue off and then it's gray instead of rust colored.
"I know just enough to keep me here, but not enough to get me out"
Old 04-08-2026, 08:32 PM
Half-Inch Stud's Avatar
I use the composite gaskets, to keep manifold heat from conducting back into the Exh port//Head.
Old 04-08-2026, 08:38 PM
One often unlooked aspect of this is the state of tune in general. A lean mixture and late ignition timing will create higher EGT's and that heat will be absorbed by the exhaust ports in the head.
fattening up the mixture a bit and making sure the engine has enough timing in it could help prolong the paint in this area.
-Jason
Old 04-09-2026, 12:18 AM
NeighborsComplaint's Avatar
I primer the head with VHT Silver and then spray the heads with engine paint avoiding the exhaust exhaust port runners. Once it’s dry, I mix VHT Blue and Silver header paint together in a Preval sprayer and lightly coat the ports overlapping the engine paint slightly. Holds up very well.
Triple Black 1971 GTO
Old 04-09-2026, 09:37 AM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
This also doesn't happen as easily with aluminum heads, so you know... can't think of a better reason to upgrade. :P
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
Old 04-10-2026, 06:02 PM
70 bird's Avatar
70 bird 70 bird is offline
I gave up trying to keep them Pontiac blue, I sprayed the ports with VHT flat black header paint. It doesn't look that bad and I don't have to look at ash and rust anymore.
Old 04-10-2026, 06:12 PM
It’s a Pontiac.
The paint burns.
Part of the charm of owning a Pontiac V8.
Old 04-10-2026, 07:17 PM
P@blo's Avatar
P@blo P@blo is offline
Matches my burnt intake exhaust crossover paint. Love it
