OHC-6 TECH Over Head Cam projects, questions and advice.
Old 04-09-2026, 08:38 PM
Default Opinion on 67 Firebird Cammer on Ebay
Looks like a fairly solid car, but I suspect it was originally a manual transmission 1bbl car. It has a Clifford 4bbl intake and vintage Clifford headers, and a recently installed carb.
Things that make me think it was not a Sprint are the Clifford parts, the strange Power steering pump bracket, the Alternator moved to the passenger side, no indash gauges.
Things I find strange are the 1/2 clear steering wheel with the base interior, and multi leaf rear springs mounted with the original mono leaf spring brackets. The rigged carb return spring, and does it have a rear sway bar added in front of the rear axle? If not what are the newer clamps on the axle tubes for?
Opinions?
https://www.ebay.com/itm/33652332907...Bk9SR6iR_7utZw
Old 04-09-2026, 11:46 PM
onetirefire onetirefire is offline
I dont know enough to tell it's original sprint.
But I am always a little amazed to see Pontiacs selling with no PHS, it is so easy to get.
Looks like a car that has seen plenty of shadetree wrenching, for sure.
Old 04-10-2026, 10:53 AM
george kujanski's Avatar
george kujanski george kujanski is online now
I lot of work required there!
George
Old 04-10-2026, 01:53 PM
Very solid looking car though.
Old 04-10-2026, 02:13 PM
I agree with everything stated, looking at the pictures again it looks like it may have had shoulder harnesses installed at some point. I can't think of any other reason for the matching holes in the headliner near the coat hooks?
Old 04-10-2026, 08:19 PM
scotty54's Avatar
scotty54 scotty54 is offline
I tried to get PHS documentation on my recently purchased Sprint, and PHS replied that no 6-cylinder cars out of Van Nuys were archived, so they could not offer any documentation on my car.
The Following User Says Thank You to scotty54 For This Useful Post:
Old 04-10-2026, 08:43 PM
What year is your Sprint? This car should have PHS available as all 67's were built in Lordstown as far as I know.
Old 04-11-2026, 12:01 PM
scotty54's Avatar
My Sprint is a 68 and built in Van Nuys, but I have no idea if it's a real Sprint. When I requested PHS documentation, that was their reply. Nothing more. I was not aware of all Sprints being built at Lordstown. If that is accurate then my Sprint is not a real one. That's okay - it's an awesome clone then!
Old 04-11-2026, 12:20 PM
TXSTARFIRE TXSTARFIRE is online now
camerjeff said all 67's were built in Lordstown. If yours is a 68 that may be a different story. Have you searched for a build sheet? That would tell you how it was originally built.
