Old 04-13-2026, 03:40 PM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
Default 1968 gto long block YS
March build automatic, looks
Clean under the sheet metal but rings and valves are stuck.
16 heads, no intake but I think I have a 68 kicking around if it helps. Rear valley pan bolt boss has been tapped for 3/8 16" should be able to be helicoiled to 5/16
This has Been Sitting under a bench for 20+ needs rebuild
As seen $1100 Norwalk delivery available with pre payment
ID:	668137   Click image for larger version
ID:	668138   Click image for larger version
ID:	668139   Click image for larger version
ID:	668140   Click image for larger version
Old 05-26-2026, 08:11 AM
Sold locally thank you for opportunity
