On second year of sponsoring a factory stock 350ci Pontiac in a sea of chevies with the rules bent in their favor.
Previous two races we’re finally getting the car sorted out with a 6th place and last weekend’s feature event running 4th place (cut tire) dnf.. The last race was a two day event with a qualifying heat race which we finished 4th. Driver (Eric) is getting some good seat time and getting quicker. Each car is clocked on lap time and the poncho was running the second fastest in a 17 car field. Racers and track officials are taking notice.
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Tri power, 4speed, barn find 1966 GTO Ragtop 1969 GTO Judge RA lll, auto 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds Factory stock oval track car |
| The Following 7 Users Say Thank You to J.C.you For This Useful Post: | ||
Great to hear!
Good job! Keep up the good work
Love this! Can you give us some details about the build? (I don't know anything about circle track rules)
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
Engines are basically mild setups with, minimum vacuum rule, .450 max lift cam, 180psi max cranking psi, factory heads (for us), chevies get to use aftermarket. Pic Eric watches while his pop is wrenching, haha
| The Following User Says Thank You to J.C.you For This Useful Post: | ||
