Old 04-20-2026, 03:06 PM
josefrees josefrees is offline
Default 72 TA: How to tell if car came with A/C or not?
Any help would be greatly appreciated!
Old 04-20-2026, 04:35 PM
65madgoat's Avatar
Post pics of what you have.
Order the PHS docs.
Check firewall and dash bezel.
Old 04-20-2026, 06:26 PM
Order the PHS docs.
Having issues posting pictures, is there anything I should look for on firewall?
Old 04-20-2026, 06:40 PM
65madgoat's Avatar
Looks like an AC firewall to me!
The Following User Says Thank You to 65madgoat For This Useful Post:
Old 04-20-2026, 08:29 PM
Held for Ransom's Avatar
Look for the partial VIN stamp near the rectangle opening.
You can see stamping in two places in this photo. https://forums.maxperformanceinc.com...08&postcount=8
So long, farewell.
Old 04-21-2026, 09:00 AM
burd burd is offline
You’d have to swap a lot out. Gotta be signs.
Old 04-21-2026, 04:33 PM
How can you tell? Thanks for letting me know your thoughts.
Old 04-21-2026, 04:36 PM
Yeah I see that now after cleaning firewall up there a bit.
Old 04-21-2026, 06:07 PM
Did you find the partial VIN on your car? If so does it match the VIN under windshield?
I can't find a non ac car firewall off hand ( I only had non AC cars except one )
Here is a pic from service manual that can kind of make sense maybe.
The heater hole is horizontal and the heater outlets are in different position. Uses a lot smaller case to cover it also.
The AC one has a vertical hole and further away I think than the non-AC one.
Old 04-21-2026, 07:08 PM
unruhjonny's Avatar
unless some real funny business was done, that's absolutely an a/c car.
non-a/c cars didn't have the large cutout - the heater box between a/c and non-a/c cars was completely different, as was the cutout on the firewall.
1970 Formula 400
Old 04-21-2026, 08:45 PM
fbody_mike's Avatar
fbody_mike fbody_mike is offline
Yes, what has been said, that is an AC car. Another way to verify is to look at the two holes where the heater core pipes come through the firewall. In the drawing above that is for an non- ac car you can see the pipes come through the firewall near the center close to the tunnel ( so easy to change the heater hoses). The AC design, as in the photo above, shows those two holes near the hood hinge area (blocked by the inner wheel well and a PITA to access).
Looking for the heater core pipes is an easy way to tell if an AC car was "converted" after the AC suitcase was removed and a conversion plate/box was added to keep the blower motor working.
I built it one piece at a time and it cost me more than a dime.
The Following User Says Thank You to fbody_mike For This Useful Post:
