Old 04-21-2026, 09:07 AM
Cammer-6 Cammer-6 is offline
Default column shift tilt for 65
A buddy is looking for a column shift auto tilt and I ran across one on ebay
sold as new for $200.
Just curious if anyone has tried one of these?
https://www.ebay.com/itm/18796701090...3ABFBMuIGwgrZn
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 04-21-2026, 03:08 PM
tempest1964's Avatar
Sounds like one heck of a deal. Just curious, who is listed as the manufacturer? Maybe I just didn’t see it. Either way, it fills a need when you can’t find one!
Old 04-22-2026, 07:45 AM
Andre's Avatar
Andre Andre is offline
What does the end user use for a steering shaft? The one in the picture seemed very short.
Old 04-22-2026, 08:42 AM
I would assume that the length is correct for a 65 A body,as its listed for such
looks to me that you take the toe plate and steering shaft coupler off the old column and re use
Old 04-22-2026, 04:02 PM
EXACTLY, the above listed tilt column is a "universal" for choice of better words, column shift tilt. Made in China, just a few years ago, avail through Alibaba for a little over a $100. Yes, I've examined one.
If one examines the limited pic & illustrations, there is no shaft that extends down over 12" to a splined end, and to which one of the cast steel bolt on flanges then attaches to the ragjoint. On a straight column (non tilt) the "64-66 A-body columns all used a welded on steel flange to attach to the ragjoint.
The small diam splined shaft on the above Chinese tilt column ends right after the end of the lower bearing retainer & the outer column tube. That will not work.
The illustration shows basically a knockoff of a '73-81 Chevy van tilt. Through the late '80's. 90's. and up into the 00's, I literally pulled near 200 of these as tilt cores to use to help build early GM tilts & '70-72 Chevy pickup tilt columns. Another interesting telltale on the cheap Chinese tilt column, note the spotwelded on thin tabs & the long ribbon style wiring connector. That style plug were not used on '63-68 GM (Saginaw) tilt columns. The early Saginaw tilt columns used a half moon shaped brown plug to attach to the dash harness. In the late '70's Packard Bell (GM) came out with a replacement turn signal switch for this style column which ended with a long flat plug. That plug could then be ziptied under the dash to the outer tube on many early tilt columns, as well as straight columns of that era. Into this flat plug went a near 10" long adaptor harness that converted over to a brown half moon shaped plug. Professional column builders did not use that such rinky dink new GM turn signal switch. Instead they bought the correct early turn signal harnesses in bulk, w/o any plug, then crimped the correct contacts onto each wire, then inserted them into the correct new halfmoon shaped brown plug. Again all sourced from GM's wiring division.
Old 04-22-2026, 04:06 PM
Incorrect column length, will need a much longer splined end lower tilt column shaft, and the small diam cast steel column flange & 7/16' 12 point bolt will have to be sourced nice used from an early tilt column, or bought new in Chinesium cast steel... not this kid.
Quick Duck search brought up these images from an old eBay Auction. Column shift auto tilt column is from a '66 or possibly earlier Buick Skylark or Olds F85/Cutlass. Note the pointer and the related slot.
https://tiltsteeringcolumns.info/196...n-original.htm
Old 04-23-2026, 08:53 AM
Good info OPH
