Old 04-29-2026, 05:19 PM
ponchorob ponchorob is offline
Default 65 bonneville rear differential source
....does anybody know what kind of rear differential is in a 65 bonneville has it 12 bolt ring gear and 10 bolt cover ? Need a new carrier but dont know which one to get tge right,,,,
Old 04-29-2026, 05:54 PM
A 65 should have a BOP 8 7/8" axle, not much support for these axles. About the only options are used and NOS, have you contacted ole Pinion head? He may be able to help. I think the same basic internals were used from 1965 to 1976 in most Buick, Pontiac, & Olds B-Bodies. Good luck. They were also used in the A-body wagons of the same era. So it might give you more search options.
Old 04-29-2026, 06:29 PM
steve25 steve25 is offline
Check out Franks Pontiac parts .
You might turn up a good used one.
He’s in Ca.
Old 04-30-2026, 04:07 PM
The '65-70 Pontiac B series rearend is known as the "P series" 8 7/8" rearend. That is straight from the original manuals & also referred to in the Hollander Interchange manuals.
For a '65 Pontiac B series complete rear (or housing), one wants to source one from a '65-67 B series Pontiac.
Franks in CA is a good source, typically much cleaner appearance housings than ones sourced up North, the SE, or in the Midwest.
I do not stock this style GM rear. Over the years, have sourced, rebuilt several, & built several up with lower ratio gears for customers.
Have also reconfigured several later "MP" series low ratio (3.23-3.42) posi carriers to mate up in '65 & '66 Catalina rears.
Further GM B series rearend lineage...
For '71 GM models, there was a revision made to the "P series" 8 7/8 rear, this required a different spline pinion flange. This style GM rear's Eaton posi unit was also reconfigured for '71 models.
The only A-body's to ever receive an 8 7/8 P series rear were the '73-77's . C-clip axles were used in this body style specific rear.
From checking out multiple hundreds of these ugly wagons, very very few were equipped with posi units.
For the '77 model year another revision was made to the 8 7/8 P series R&P (a longer pinion).
This style 12 bolt B series rear is known as the MP (modified P series), or in some manuals, that model year's 8.75 rear.
The only GM divisional usage for the early '65-70 "P series" ring & pinion & 31 spline carriers other than in Pontiac B series vehickles was in '65 & some '66 Olds B series rears. Olds began to roll out their Type "O" Olds rears later in '66 B series. The Type "O" style 10 bolt rear was exclusive to Olds divisional usage in '67-70 Olds A & B body's. Pontiacs did not come with them. Olds guys love to call the Type "O" rears 12 bolts, but their smooth 12 bolt cover is the only thing "12 bolt' about them & even that 12 bolt cover has different bolt spacing than the common 12 bolt Chevy car rear cover.
Buicks...
Big Buicks of the '65-70 era never had their own version of the 8 7/8 P series rear. Buick instead relied on the 9 3/8 BUICK rear up through at least 69 or '70, Next, a revised Buick 9 3/8 (Salsbury/ non dropout 3rd member) style rear was used under '71+ Buick 455 powered Electra's & Rivieras. As the '71 model signaled the beginning of Corporate GM usage rears, certain engine specific models of '71 B series Buicks also received 8.5 rears as well as the afore mentioned '71+ 8 7/8 P series rear.
The Following 2 Users Say Thank You to 'ol Pinion head For This Useful Post:
Old 04-30-2026, 06:45 PM
stevep's Avatar
stevep stevep is offline
I have a complete 65-66 3.23 single track in Boston for $7.50
Old 05-01-2026, 09:52 AM
Thanks for the good info OPH.
